Question about Acer Professional P211 21" CRT Monitor
Acer monitor lcd
Have a new monitor and have been using it for 2 days now cant get into windows says no signal
  • 21 Answers
No signal means there is no communication between your monitor and your system unit.check and be sure your monitor signal cable is firmly connected,if nothing happens, try the monitor on your friend's system.if no change then try and replace the monitor signal cable, eyo7 eyoifiok2005@yahoo.com
Posted on Feb 28, 2007
I cannot adjust the brightness on my Acer 5420-5687 laptop. The laptop had frozen so I unplugged it and took out the battery which reset the brightness. I tried using Fn key and holding the either sun...
I'm sorry my friend but seems your LCD monitor having problem. There are three options with your LCD monitor. Option 1: repair your LCD monitor *commonly problems are the LCD inverter*. Option 2: Replace LCD monitor with a new LCD monitor. Option 3: Instead using your dim LCD monitor plug CRT or LCD monitor external serve as your monitor. Have a nice day.
Jan 26, 2011 | Acer Extensa 5420-5687 Notebook
No signal everythings plugged in and turned on still says no signal in goes to standby mode.
1. change the VGA cable and test.
2. Plug to another PC or notebook and test.
if still no signal, it might be the display board inside the LCD is faulty.
You need to get a certified technician to fix it.
If cost is higher than 1/3 of a new 18.5" new :LCD monitor; I think you need to think of purchasing
a new LCD already. As new LCD will cover you with 3 years warranty.
take care.
Jan 03, 2011 | Acer AL1916W 19" LCD Monitor
How will my brand new monitor work with windows vista?
Hi , The reason monitor does not sync , You need to reduce the resolution and then connect the Acer monitor and then adjust the display according to your requirement.
Jan 11, 2009 | Acer 19" LCD Monitor
Drivers for the Acer LCD monitor X193W under Windows XP Pro.
The acer LCD monitor is plug and play.You don't need a driver.But unless you have a graphics card that supports at least 1440x900 you have problems. Also if your card has a div connection, use that instead of the analog connector, The monitor comes with that connector. Use the old one to connect a second CRT monitor if you want. Don't connect both to the lcd monitor and to the computer unless you are using a second monitor. Like everything these days, every purchase seems to need an upgrade of sorts, On board graphics **** anyway. Buy at least a 128 MB graphic card with a digital connector and more RAM never goes astray.....
Ron
Nov 09, 2008 | Acer X193W LCD Monitor
I cant get my acer aspire one to connect
your describe: connect a laptop VGA out to a monitor but no signal: you need check
1) newer monitor have two signal interface (analog or digital) and you may try to do a logical change the signal way by select buton
2) any laptop have two way display (local LCD or extenal VGA) change by the key (fn+f key showing creen icon)
Nov 08, 2008 | Dell E207WFP LCD Monitor
Acer Aspire 5585 Laptop LCD Problem
You need to replace the inverter of your lcd screen.
Oct 02, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
No Signal
Probably the settings on the computer graphics card output.
You need to selct the external screen.
Just to be sure it's not a screen fault, are you able to test it on another PC (desktop, not laptop)?
Jan 05, 2008 | Acer AL1916W 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer Professional P211 21" CRT Monitor Logo
251 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
