Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore elite trio 596.76539500 control panel says OFF.
    Problem Solver:
  • 13 Answers
On a Kenmore Trio 78729 made by LG, open left door and push the Ultra Ice and Refrigerator button simultaneously for 5 seconds. The display will change from 0 OFF to temperature settings.
Posted on Feb 15, 2009
5 Suggested Answers
SOURCE: Just bought a kenmore elite bottom freezer trio
I just purchased a similar model and had the same frustration. Finally called the store and it was in DEMO mode. Open the freezer draw and hold down the Ultra Ice & Refrigerator Temp buttons simultaneously for 5 seconds. That worked for me and hope it will do the trick for you.
Posted on Jul 12, 2009
SOURCE: Kenmore Elite Trio 795.7519
This is the 1st (and easiest) step to take:
1. Turn power off to the refrigerator (i.e. unplug)
2. Leave OFF for at least two minutes to allow the CPU to reset
3. Turn power back on (plug in)
This solves 98% of these problems with the Kenmore Elites.
Step two would be to call service.
Posted on Apr 26, 2008
SOURCE: Kenmore Elite Trio 596 73503200
Did you ever get the problem fixed with the compressor noise
Posted on Jul 09, 2008
  • 8 Answers
SOURCE: Kenmore Elite Trio electronic panel displays 'Er IF' and touch buttons not working
I have the same problem!
Posted on Nov 04, 2008
Elite Trio. What caused it to die suddenly after only six years?
I was going to explain a device called a "defrost timer", but I did a search on your fridge and found the following important information for you to check on FIRST!
CPSC Maytag Corporation Announce Recall of Kenmore Elite Brand TRIO Model...
Info on Recalled LG and Kenmore Elite Trio Three Door Refrigerators
Oct 01, 2015 | Kenmore Refrigerators
My Kenmore Elite Trio Fridge is leaking water from under the front of the machine. It is not the water connection. Do you know what the problem might be?
Your defrost drain tube is probably clogged with ice or something. Defrost your refrigerator (put towels around to soak up any excess water), then after it's defrosted, take off the back, lower panel and look for a 1 inch diameter tube coming down from your refrigerator. Remove it and clear out any blockages and then re-assemble everything.
Oct 15, 2014 | Kenmore Refrigerators
No lights on control panel kenmore elite trio 795 trio
What is the model number of your unit?
Nov 12, 2012 | Refrigerators
Kenmore Elite trio Error 15
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio
dh means there is a defrost problem with unit you need to repl the controler in evaporator. you will have food loss if not taken care of asap if is under a year old call the tech out there
Oct 14, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite Trio
unplug the unit from the wall and re-plug it in and see if the display goes back to normal. It will stay that way untill the next defrost cycle and the code out again. Most likely there is a controller located on the right side of theevap that may need replacing. The code is saying there is a defrost problem.
Sep 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
872 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
