Question about RIM BlackBerry ® 8830 Cellular Phone
I'm trying to set up my new blackberry 8830 to work with motorola and jawbone bluetooth units. i've enabled bluetooth on blackberry. i've set discoverable to yes, and the led connection indicator to on. it will not find either model bluetooth unit when running an add a device search. any ideas what I can do?
  • lm_bass99 Dec 17, 2008
    There was a special mode on bluetooth unit itself to have blackberry sync with it. The Sprint store ended up knowing just what to do so heading into ones cell plan provider is a quick solution too.
    Sniper:
  • 114 Answers
You also have to have the headset on pairing mode also during the time of the attempted sync, see your documentation on your headsets on how to set it for pairing mode.
Posted on Dec 16, 2008
Have a jawbone bluetooth ear piece trying to pair it with a blackberry cant remember how to pair it
I have two jawbone headsets and they won't pair with our blackberry phones. Can you help me
May 20, 2010 | Cell Phones
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
Same problem. can't find pin# for H721 motorola bluetooth
The Default Pin for most Motorola is either 0000 or 1234. try those.
Aug 14, 2009 | Samsung Executive Black Side Leather Case...
Bluetooth, and my blackberry
Check out the updated Bluetooth firmware specially for Blackberry devices on the Pioneer website.
Mar 28, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Blackberry 8830 - World - Problem Pairing with Bluetooth
I am having the exact same problem and cannot seem to resolve it; have you had any luck over the past month?
Mar 06, 2009 | RIM BlackBerry ® 8830 Cellular Phone
How do I pair a black berry 8820 to a motorola ihf-1000 bluetooth
Here is a link that will direct you through the entire process. You will need to select the Blackberry 8830 as your phone, but the instructions should still be the same. Let me know if you need further, and I can give you more.
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=38b5f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=0a50d590556c9010VgnVCM1000008206b00aRCRD
Feb 21, 2009 | RIM BlackBerry 8820 Smartphone
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
HandsFRee Problem
I have MANY of these radios BRAND NEW with codes for sale if anyone has to replace a bad unit. $270 8b748a8.jpg
Sep 10, 2008 | 2004 Acura TL
Motorola S9 and Blackberry 8830
To stream music to the S9 the phone needs to support stereo bluetooth or in other words A2DP. The Blackberry 8830 unfortunately doesn't support this and only supports regular mono bluetooth. This is why no music is heard from the S9.
Dec 19, 2007 | LG Prada KE850 Cellular Phone
Motorola Bluetooth Hands-Free t305
I have been told by both Motorola and LG that it is a Bluetooth profile compatibility issue. I don't know that there's anything that can be done.
Nov 21, 2007 | Motorola Mobility Bluetooth Hands-Free...
RIM BlackBerry ® 8830 Cellular Phone Logo
266 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
