If you directly plug your laptop to the power outlet and there is no sign of power indicator then probably the input power supply got fault. if there is indicator then the switch maybe error or if the laptop boot and cannot continue ..maybe memory and video card. first try to verify the power input of the laptop.
may this initial help,
melnavz
It could be a bad battery, or a bad power plug which would not pass power to the battery. If possible, replace the battery with one that you know is fully charged. If that works then you will have to have either have the adapter checked or the plug itself may be loose and needs to be re-soldered. If it did not work then something else is loose and you should have it taken in for a complete exam.
Before you start 1) Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need. 2) Purchase the battery through Acer or a local or online computer parts dealer. 3) Turn the laptop off and unplug it. Also unplug any external hard drives, cameras, or other external devices. 4) Turn the laptop over (bottom facing up), then touch something metal to remove static charge. Removal of the CMOS battery Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery. The battery should look something like this
Plug the new CMOS battery cable into the motherboard. Slide the battery partially under the laptop casing (somewhere to hold it in place), then align the cover with the slots on the bottom of the laptop housing. Replace the screws then turn the laptop back over.
Finalizing
1) Turn the laptop on.
2)Enter your BIOS (usually by pressing the "Delete" key) before the operating system loads.
3) Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
Reason: Anytime the CMOS battery is unplugged for more than a few seconds your BIOS will be reset to the default manufacturer settings. If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3 to 5 seconds to correct the problem.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
