Question about iLO 3200 32 in. LCD Television
42" ILO LCD HDTV HMDI
I have a 42" ILO LCD TV. I finally got around to trying to use the HDMI input for it and cannot get the Blue Ray player to recognize it. When on the HDMI input the TV shows "NO INPUT" Upper left hand screen. Does anyone know how to resolve this issue?
  • Dick Ed Jan 07, 2009
    Got a blu-ray disc player for Christmas, tried hooking it up to HDMI port on Ilo LCT42HA36 (42" LCD). All i got was a blue screen that said no signal. Then hooked up sat receiver I know works, got same no signal.
snakehead
  • 1074 Answers
SOURCE: ilo 42'' EDTV
if your tv is on warranty take it back for another one the tv is factory defect.if in the future you need manual for your electronic items go to www.service-manual.net good luck.
Posted on May 14, 2007
SOURCE: ILO 26" LCD HDMI TV
I had the same problem at first. Then I went back to fry's and bought a new DVI cable. Make sure you bought the right one.
Posted on Dec 04, 2007
  • 103 Answers
SOURCE: HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
Posted on Mar 03, 2008
  • 231 Answers
SOURCE: PDP4210EA1 Plasma TV black and white pic on reg RF input-no signal on other inputs
does the DVD player connect to the same port as the regular cable vision ?
If no I would be looking at the port that the cable vision connects to, to see if part of that circuit is shot.
Another question, has the T.V. been moved from one location to another just prior to this happenning? As plasma T.V.s can only be tilted on a 15 degree angle.
Posted on Oct 16, 2008
SOURCE: ilo 42"widescreen lcd tv
I hooked a sylvania 220sl8 dvd/cd/vcr, The vcr works, the dvd does not. Why?
Posted on Oct 18, 2008
When you chose the settings menu what do you chose to set the tv to hdmi to get the dvd/blue ray player to play
There are two HDMI inputs on your TV, so, depending on which input the DVD player is plugged into, HDMI 1 or 2 , that's the one you choose. The menu should list the inputs as HDMI 1 and HDMI 2.
May 19, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
I'm staying at a Hotel in Atlanta that has 42 inch LG LCD TV's and I'm trying to connect a DVD Blue Ray directly to the TV with HDMI Cable and set the TV to HDMI input setting and Nothing happens except...
I would call the front desk. They usually have a maintenance person who can help you with the connection. If the TV HDMI port is not functioning, they may be able to swap tv's or move you to another room! Good luck!
Oct 09, 2010 | LG 42LC2D 42 in. LCD HDTV
When i try to play a Blue Ray DVD, the LG LCD tv gets a swath of bright green random pixels across the middle of the screen. The player is connected by an HDMI cable. I have replaced the cable twice,...
Pickled! You did right by checking the cables, the tv inputs and as well the output on the blue ray...even by replacing the blue ray. Which leads to a problem within the tv monitor. I can only guess there is something in the software of the tv that is causing the problem. I can only suggest two options. If can connect the tv to a network via CAT5 cable, you can do a frimware update to the tv. Sort of like a software update. If it is not available, try to swap the HDMI cable for the 5 RCA component video. It will still carry HD signal, just not as crisp as the HDMI. I would be floored if the same thing happened with the component cable.
Jun 30, 2010 | LG 42LC2D 42 in. LCD HDTV
Invalid format error with P1600 blu-ray and LG LCD TV 42"
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
Jan 17, 2010 | LG 42LC2D 42 in. LCD HDTV
PS3 problem with 42LG50 tv.
So I did finally find a solution....I returned my PS3 for a brand new one. Turns out it was my PS3. This is what I did...I bought a blue ray player, I connected the hdmi to my TV....no problem. So it wasnt my TV or HDMI cord. Returned the blue ray player for my money back, and returned my PS3 for a new one. Problem solved. Seems like alot of work, but it was the only way I could troubleshoot my issue. Just for kicks, try using another HDMI cord. I went through 3 different kind. Good luck.
Jan 22, 2009 | LG 42LG50 42 in. LCD HDTV
Can not get my new 42 " Aquos TV to work with my new blue ray DVD
A blu ray player will play on any television. The television might not however have the highest resolution to display the full capability of a blue ray. That being said, the blu ray player may be faulty the connections may be incorrect. I would recommend running an HDMI cable from the A/V out on the blu ray to the HDMI input on the TV. GOod Luck
Dec 23, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
iLO 3200 32 in. LCD Television Logo
163 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
