Question about Insignia IS-LCDTV32 32 in. Television
Cannot view dvd's, can hear the player running.
What channel should I have on to view a dvd?
Go to input on remote switch to video 1 or 2 make suren tv is on 4 also can go to aux if dont wotrk
Posted on Dec 10, 2008
I can't get the DVD player to view dvd on tv
hi konni.
this is all i could find .
DVD player not working with TV By Charlotte Parker 25 Aug 2017
You've got your Sky Box, your TV, your DVD Player and your surround sound; you've also got your digi-box, your DVD recorder, Blu-Ray Player. With all that equipment, if something goes wrong it can be tricky to track down the issue. This article explains why your TV isn't playing DVDs and how to get it sorted out.
Figuring out the problem
Figuring out why your DVD Player isn't working with your TV is a process of elimination, so work through the steps below to figure out the cause of the problem.
The problem could be:
  • The connector cables/connections.
  • The DVD disc itself.
  • The DVD Player's optical reader (the lens which 'reads' the DVDs).
  • The TV.
Before doing anything, check all your connector cables. Make sure that all connections are in properly, and that the cables are in the right place.
One of the most important connections is the cable that runs between your TV and the DVD Player. If it isn't in place, then your TV can't read the information from the DVD Player and the film won't appear on your TV.
The DVD disc itself
Check for scratches, chips, smudges and any other marks. Test the disc isn't the problem by trying a different one in the player. If the new disc works, then the first one might need replacing.
The TVTry changing channels. Lots of TV's have a default channel specifically for DVD players. Have a look between the channels to see if the DVD menu appears.
On modern televisions, especially those connected to Digi-boxes or Sky Boxes, there's usually a 'Source' button on the remote control. Find it and go through until you reach the right setting for playing DVDs. To go back to watching normal TV channels after the DVD has finished, go back to the source button and change back to the original source.
That should be all you need to know to get your DVD player working with your TV
if none of above works then try putting a lens cleaner through it to try and clean the lens that reads the disc.
Nov 05, 2017 | Televison & Video
My movie does not show on my tv, the dvd player is working, I can hear it running and the numbers are changing
Perhaps it isn't connected properly or the TV is not set on the proper channel to view from an accessory.
May 01, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
My television does not have an audio output so i connected the rs 110 to my cable box and it works fine...however i also have a dvd player connected to the tv video input and for some reason i cannot hear...
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
  1. Look on the cable box to see if there is an option for AUDIO in (should be a pair of red and white RCA plugs)
  2. You want to run an RCA cable from the AUDIO OUT of the DVD player to the AUDIO IN of the cable box
  3. Then select the Auxillary input from the cable box and you should be able to hear the DVD
Alternatively you can run both DVD audio and video through the cable box
  1. Look for DVD IN on the cable box
  2. Connect the audio/video cables from the DVD player to the cable box
  3. To watch a DVD, switch to the DVD input on the cable box
Alternatively you can run the cable box through the DVD player
  1. There may be inputs for AUDIO and VIDEO in on the back of the DVD player
  2. You want to connect the outputs of the Cable box into the back of the DVD player
  3. You can then select the input on the DVD player to control whether you see/hear the cable or DVD
Mar 08, 2011 | Sennheiser RS 110 Consumer Headphones
I want to watch a movie on my DVD player so what channel should i be on to view the movie. Can hear the movie. Carl
Well is your DVD connected to your Tv by AV cables?
If so try looking for a "SRC" or something simular, which is Source. This changes from Normal tv channels to DVD/GAMES.
But you said you can hear the movie; maybe you put the Video In cable into the wrong port. I know my parents always do this and I have to fix it for them.
Dec 15, 2010 | Televison & Video
I can view the video, but there is no audio playback....what's up?
check the leads,perhaps you have connected the audio cable wrongly.usually yellow is video out from DVD player,red is left channel audio & white is right channel audio.
Aug 23, 2010 | Apex Digital AD-1200 DVD Player
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
DVD player wont work with TV
First, make sure that the units are connected properly * I know it's obvious, but I did it myself one day * Then on your T.V. remote, try hitting INPUT and it should run on your VIDEO channel.
This will work 99.99% of the time. Let me know,
Thanks
Justin
Please rate me.
Jan 07, 2009 | Memorex MVD2042 DVD Player
Can't view picture, but can hear sound
Are you trying to record TV signal onto a DVD, or are you playing back? What make & model is your TV and DVD player/recorder?
Oct 22, 2007 | Yamaha RX-V620 Receiver
No picture on Television
You have provided incomplete information. What do you mean by 'dvd player works'? Do you mean you are able to view the DVD movies on the TV? Or does it mean that there is power and various lights and indicators on the DVD player?If you are unable to see picture - both while viewing DVDs and also Broadcast channels, then there is a major problem with the TV.Get a professional to have a look, then. But if you are able to view DVD movies, but unable to view broadcast channels, then it is a simple problem of input selection. In this case just select the TV/Video or TV/AV button on your remote, if there is such a button. If no, then use the menu and scroll for input, and then select Tuner. First clearly state what your problem is. Only then we can give you better advice.
Aug 23, 2006 | Jensen JHT-350 System
Insignia IS-LCDTV32 32 in. Television Logo
37 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
