Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Error code er ff on my kenmore elite bottomfreezer model 795.7756
I get error code ER FF. Freezer frosty but working. Fridge is warm. Please help.
  • 12 more comments
  • lilytoy Dec 20, 2008
    I have the same problem.  Help!
  • rhdante Jan 29, 2009
    I have the same problem. For the last four months the refrigerator was making a rumbling noice and now a ER FF code is showing on the control panel.
  • Angelica Garcia Feb 18, 2009
    I had this same problem about a month ago. We disconnected and restarted and it work. Now I'm back with the same problem. Do I need to replace the fan? Please advise.
  • Anonymous Apr 26, 2009
    Ok, how do we all ban together for a recall?. Let's do it. $1800 for a fridge that doesn't last more than 18 mos is rediculous. I'm happy to start the ball rolling.
  • dcmc41 Apr 26, 2009
  • Anonymous May 07, 2009
    The really stinks! We're having the same problem, and everything is defrosting & warm! Model 795.7756
  • D Walker Jan 20, 2013
    I have that error code but my freezer remains frozen. My refrigerator is not cool at all. Is this still the freezer fan?
    I have that ER FF but my freezer is freezing fine. It is my refrigerator that is not cold. What can I do?
  • Cmdr Bubba Mar 19, 2013
    I have the same problem with the model 7957205. Contacted Sears and was told by a technician it was a design problem. $510 to fix on a fridge that is barely a year old. I contacted management at Sears who blamed it on me for not buying the extended warranty. I contacted LG who referred me back to Sears. I will rejoice when Sears goes under, because of the poor business practices they have adopted. Shame, they didn't use to be this way.
  • Barry Bessinger
    Barry Bessinger Aug 22, 2014
    My 5 yr old Kenmore Elite just started this er ff code. The code appears and disappears randomly. The fridge is not quite as cool as it should be and ice cream in freezer is not frozen hard either. I am going to empty the freezer and try your fix over the weekend. Will let you know of my results. This fridge can't hold a candle to the 20 yr old Kitchenaid that it replaced.
  • Barry Bessinger
    Barry Bessinger Aug 24, 2014
    I did the fix, removed all ice from around the fan and blew it with a hair dryer. Put it all back together and got no error message for a day or so, but now error message is back. Despite error message, freezer & fridge seem to working ok and there are no strange noises. Any ideas anyone ?
  • Perry K
    Perry K Nov 26, 2014
    make sure you let it completely dry out. i used a hair dryer, and a small space heater. pointed into the freezer for a good hour. if its not completely dry, it will freeze back up again. this process usually lasts 6 months or so. good luck!
  • Anonymous Jan 16, 2018
    Ice build-up (and condensation in the fridge section) likely comes from humidity in the outside air getting into the fridge. Try to avoid excessive door openings and durations of both fridge and freezer since both share the same air. Condensation in the fridge suggests you have this problem.
    I turned off the unit for 2 or 3 hours with the doors closed. Then removed the freezer upper tray and ice tray and used a hair dryer to warm up the rear of the freezer. Not that much water came out so I assumed that the ice buildup was minor. I checked the rear air inlet and outlets and there was very little dust and adequate air movement. Running fine now.
  • Nelly Perez Jan 23, 2018
    Recall!!!!! Lost $300 worth of food!
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Posted on Dec 24, 2008
  • 5 more comments
  • Sundae Flannigon Oct 18, 2010
    Thank you so much!!!! I called Sears today because I had the same code. They told me that my warranty ran out the first of the month and because there was a problem with the unit they would not extend the warranty!!!! Then they proceeded to treat me like a moron and inform me that "only a 'professional' technician should ever repair any appliance" and asked when I wanted to schedule repair? AT $75.00 an hour PLUS PARTS!!! I told them I would contact them when and if I decided to use their lowsy service and disconnected!!! I then let my fingers do the walking through cyber space and low and behold!!! Here was my answer thanks to you!!! My Fridge is now fixed and it didn't cost me a penny!!!! Thanks again, and I am IN if anyone truly wants to start a recall on these dumb things!! Blessings, Sundae
  • glabbe941 Nov 11, 2010
    I'm with you. We have the same issue with ours.I too called Sears and explained the error code....before I could even finish telling the person on the phone the issue, she interrupted me to say "Oh you will need service. When would you like to schedule" She was all too eager to charge me for service, but would make no reccomendations as to what the problem might be. I purchased a number of appliances to furnish my new home. I have already had one extremely frustrating service with the Sears service department. . These experiences will prevent me from ever purchasing another appliance from Sears again. I will buy from my local appliance dealers that will provide local service. I will listen to you all and give the hair dryer solution a try. I vote for a recall on these lemons.
  • cheesehead79 Mar 01, 2011
    So I did what you said its still doing it. Did anybody have a service guy come out to fix the problem and how much did it cost?
    So I did what you said but still doing it....Did anybody get it fix and how much?
  • duaneblair Mar 26, 2011
    Like Lilytoy said. Error code FF was the fan frozen up in ice. I fixed it after it was only 18 months old and again about 18 months later. I just put frozen food in a camp cooler while I melt the ice with a hair dryer. With the bottom freezer drawer removed the back panel snaps out at the top. You'll see the ice built up around the coils and fan in the upper right. I had it all melted out with the hairdryer and back together in an hour.
  • electonictard Oct 25, 2011
    Mine just did the same thing! Fan was making a loud noise for a few days and now isn't working at all and that error code is coming up.
  • Ingrid Gregory
    Ingrid Gregory Oct 30, 2013
    THANK YOU, lilytiy!!!!! You are a life-saver! :)
We have had the over under now for 3 years. About 2 months ago started getting ER FF codes. SEARS SUCKS.....not only do we have the fridge problem but have had major issues with their dishwasher and have gone through 2 grills lasting about 18 months each. Their customer service is the worst that I have EVER dealt with and their products ****. I will NEVER EVER buy another Sears product as long as I live. BUYER BE WARE.....I am not speaking from one bad experience, rather multiple product types across 1/2 dozen years. THEY SHOULD BE ASHAMED OF THEMSELVES.
Posted on Oct 14, 2011
  • Kris Levario
    Kris Levario Nov 21, 2018
    We paid for extended warranty/repair plans on all our appliances, was money well spent, the dishwasher rack broke constantly, they finally replaced it with metal components, not plastic, it has been fine ever since, imagine if they had been metal all along?
    Our electric range has never worked correctly, and the front burner doesn't work at all, it shorted out, but our extended warranties are expired, we fixed the control panel, which literally fell out of the range, it needs a new one, we can't afford it yet.
    The refrigerator door RUSTED because the ice maker seal keeps failing and water from melting ice was dripping out continually, they fixed the flap twice, but still leaks, the ice maker stopped working, we had to replace the water lines twice to the ice maker, and now the fridge is throwing an error code.
    These appliances are substandard, it is sad really, Kenmore used to be a great brand. They are 5 years old, the fridge we replaced was 12 years old, it still worked too...it wasn't a Kenmore Elite.
  • Kris Levario
    The word stu pid is a swear word, but not the word sucks?
I call for a recall...I keep having this problem at least twice a month.
Posted on Apr 23, 2009
  • 1 more comment
  • ong123 Jan 29, 2011
    This fridge is manufactured by LG. Thats who you have to go to for a real resolution. Even if Sears goes through the motions, they will end up referring you to LG and IF LG doesn't take care of the problem, then Sears will consider talking to you. We have this fridge, and only 6 months after purchasing it, it flooded my kitchen, to the tune of $50K. LG offered to pay us about 1/2 that amount, we are still arguing with them. Now we have this issue. I'm so sick of this beautiful piece of ****.
  • dr_pintyeg
    dr_pintyeg Jul 06, 2013
    Our refig is a year old, and the ER FF codes keep coming upp. The refig is stop working.
  • John Walsh
    John Walsh Oct 27, 2015
    Ditto on our Sears Kenmore Elite. Sears has a factory repair which fixes ER 1F error. We got that down and the ER 1F went away. 5 months later, we are getting the ER FF that you all mentioned. Go for the RECALL!
Recall!!
Posted on Apr 09, 2009
    New Friend:
Put me down for a recall also. I have the same problem, hopefully the extended warranty will take care of it. No more sears **** for me, or LG for that matter.
Posted on Apr 07, 2013
  • jttl9598 Oct 07, 2013
    I have the same problem the er ff comes on. The light in the fridge part doesn't come on. A piece of plastic fell off the roller bar in the freezer. Don't buy this Kenmore 795.78099! It's a piece of junk! I called to have it serviced yesterday, was told it would be a week before someone could come out to look at it. I told the guy at Sears to forget it! I wlill never buy from Sears again!!!
We have had a fridge 2 years and it did the same thing. Its bull **** whe you pay this much for something and it goes out in no time. We would like to be in on this recall too. Thanks
Posted on Feb 07, 2010
    New Friend:
Mine just did the same thing! Fan was making a loud noise for a few days and now isn't working at all and that error code is coming up. ER FF code came up after one an half year of purchase. I just defrost it, and will see it is working,or not? That is America problem today, everything is made with cheep labor (Korea,China..)
Posted on Jul 06, 2013
    New Friend:
I agree "RECALL". We have had our frig for several years and have had more problems than I have ever had with a frig! This er rr code every so often and we have had our mother board replaced because the lights in the frig wouldn't shut off!! The lights were melting the top of the frig plus spoiling the food.
Posted on Jul 11, 2013
  • Margarett Moreland Sep 25, 2013
    I honestly feel like putting it behind my truck & dumping it at Sears' front door!! & driving off let them deal with getting rid of it!! >:{
    New Friend:
I also have a Sears model 795.77249602 with the error message "er ff." I tried removing the back plate and cleaning the coils in the rear, defrosting the unit, unplugging/plugging back in etc. to no avail. The freezer rails are broken and the water stream that comes out of the door is ridiculously slow -- even after replacing the expensive cartridge. I got duped for a $1200. I refuse to throw good money after bad and will get a different refrigerator. Put me on that recall list! I will not buy another Sears/LG product.
Posted on Aug 15, 2014
    New Friend:
This fridge is the worse I have ever owned.Both upper door hooks broke early on.Sears fixed one, the other broke 13 months in and they refused to fix it.Now I have error and ff .So far if I unplug for a few minutes and restart it goes away for a while.This fridge is under 4 years old.I am ready to cut my losses and dump it .Never again Sears ! RECALL RECALL RECALL!!!!!!
Posted on May 12, 2014
  • 4 more comments
  • Joe Leonardi
    Joe Leonardi Jun 06, 2014
    Update on this piece of junk fridge,I defrosted it and removed the upper center panel in the fridge and as I thought the evaporator fan is not working.Called sears for a repair appt. 7 day wait,I was told the technicians are very busy-NO WONDER!
  • Joe Leonardi
    Joe Leonardi Jun 20, 2014
    Technician came after 7 day without the uses of the fridge and my diagnosis was right the evaporator motor was the problem.
  • Lori Chandler
    Lori Chandler Jun 29, 2014
    I also have this refrigerator model #795.71302.011. We also had to codes ER FF. We have previously had the loud noise of the fan in the freezer hitting ice and have unlpugged it overnight and it seemed to fix it. Now the freezer works but the refrigerator doesn't.
  • Joe Leonardi
    Joe Leonardi Jun 29, 2014
    Lori,I would bet that the evaporator fan motor is not working and will need to be replaced.
  • Perry K
    Perry K Jun 30, 2014
    Joe...check out my solution above, #9. it works. You won't have to replace anything. here's the video:
  • Perry K
    Add a Commenthttp://youtu.be/tA166b1-15M
    New Friend:
Recall! I feel fortunate I at least had mine 5 years - but still disappointing! Have a repair man coming this morning (not Sears repair) - but don't know if I want to throw good money into it.
Posted on Sep 15, 2016
    New Friend:
I don't even wait for the er ff code to come up. I can now hear it, and my food is not that cold. I take the freezer door off, back panel, etc...use a hair dryer and then a space heater to dry it out. Takes me a little over an hour for the whole process. I've done it enough times. Sucks that we pay so much for a lot of aggravation.
There is a youtube video i used to help me the first time. It's really not that hard to do, and much better than calling Sears(which btw I called the first time and they changed a screen or some BS like that...cost me $300). Here's the video:
Posted on Jun 30, 2014
    New Friend:
I have a Kenmore 79572483411 and the same thing is happening, 16 months old. I have already spent $750 to fix it and we have not yet solved the problem. So far I have replaced the entire evaporator fan kit ($500 with service techs labor) and the main pcb control board ($220, did it myself). Now I'm waiting for the evaporator fan motor ($67), which Sears claims "should" solve the problem. I'm done after this. The days of affordable quality appliances are gone, as long as all these stores let companies like LG make their parts.
Posted on Aug 07, 2017
    New Friend:
The blow drier and resetting the power worked for me as well. I'll see how long its going to last. First time this has happened in the 10 years we've had it.
Posted on Apr 22, 2017
    New Friend:
Sears has really gone down hill in product quality and support. I called 3 times while under warranty. They say there is no forseeable day they could send someone out. They say someone will call you back to schedule. No one ever does. Never buying any Sears product again until they change. This is not your grandparents Sears anymore!
Posted on Oct 02, 2016
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Error code ER FF
code for defective freezer fan motor. ER FF
Sep 21, 2009 | LG LFX25960ST Stainless Steel French Door...
FF error code
The ER-FF problem that you have is: ERROR -FAN FREEZER so it means that you have a problem with maybe the fan motor or if it's a bottom mount freezer maybe ice built up on the fan motor so it's blockin the fan motor.
Hope i helped u a little bit ! :)
Francois Pelosse
Jan 19, 2009 | Freezers
My refige is warm and my freezer is frosty
lg american fridge freezer my fridge is working ok but my freezer isnt can u help please ty
Dec 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Er FF ON THE BORD
FF usually means the freezer fan is not working. If the fridge is cooling poorly, check to see if the fan inside is running while the compressor is running. If not, and if there's no ice jamming it, then you need a new evaporator fan. If the fridge is cooling normally and the only symptom is the error code, then it could be a problem in the electronic control.
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not working
Error code ER FF and evaporator fan makes loud noise
Aug 15, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
21,926 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
