Sony projectiion TV SXRD (SILICON X-TAL REFLECTIVE DISPLAY) WHILE I HAVE A PRETTY GOOD FLESH TONE FOR DISPLAY--THERE IS A DEFFINITE SHARTRUSE (YELLOW GREEN) THAT WANTS TO DOMINATE MY PICTURE. CAN YOU ADVISE?
  • 320 Answers
Sony is aware of this problem and has extended the warranty for the optical block, which is the source of your problem. You can find out more by pasting the following web address in your browser:
http://ciscdb.sel.sony.com/US/perl/news-item.pl?mdl=KDSR50XBR1&news_id=185
Posted on Dec 10, 2008
Sony sxrd 60a2000 remote stopped working
I guess the infrared receptor in the TV is defect. No choise but to repair but I do not know if it is worth it as one gets a Flatscreen pretty cheap nowadays.
Dec 09, 2013 | Toshiba 32A33 32" TV
No colour in bottom right corner
I believ you have an issue with the optical block on your set. Light produced by a high-intensity projection lamp enters the optical block and is split into three paths (one each for red, green, and blue) by a series of lenses, condensers, mirrors, filters, and/or beam splitters. Each color has an LCD assembly with polarizing filters and a liquid crystal microdisplay panel (approximately 1" across). On Sony's "3LCD" models, the light is transmitted through each LCD panel, and, on their "SXRD" (Silicon X-tal Reflective Display) models, the light is reflected off each SXRD panel. Finally, the three separately colored images are combined with a special prism into the final full-color image, which is then projected/enlarged onto the back of the screen by a projection lens.
The following annotated photo shows various parts on the optical block of a 2004 3LCD model KDF-55WF655 (note that the LCD panel cover has been removed):
dcramer531_82.jpg3
Either the block is starting to wear out or you have something blocking the lens, such a dirt or something has fallen and is blocking the lens
Feb 20, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Sony SXRD power led is blinking and the picture
your power supply has failed repair/replace it
Mar 20, 2010 | Sony KDS-70R2000 70" SXRD TV
Sony sxrd tv does not turn on
If you have power to the outlet, then remove the back cover of tv. Check that the glass bus fuse isn't bad. It should have the thin wire inside running all away across the fuse.
If the fuse is good, then the high-voltage tranformer (power supply) is bad. You can get a replacement from tigerdirect.com
Dec 17, 2009 | Sony KDS-70R2000 70" SXRD TV
Sony sxrd --cuts off after a few seconds then cut itself back on.
Symptom shows lamp is weak and requires replacement.
Please buy Sony original lamp for TV safety and good picture result.
May 31, 2009 | Sony Televison & Video
Well i really want to know what level the coular and brightness lvel has to be on a toshiba t.v
You can set these controls to your liking, though a lower brightness setting might increase the life of the screen. First, set the brightness and contrast to a level that is pleasing to the eyes, then adjust the color to look realistic - enough color without being disturbing. If faces area look greenish or purplish, then also adjust the tint (sometimes called Hue) until you get accurate flesh tone. Flesh tone is the best thing to adjust for; when you get good flesh tone, the rest of the picture will look great. ALWAYS make adjustments during a live news broadcast, which tends to have the most accurate balance of brightness, contrast, color level and hue. Note that commercials are all recorded in different studios with different settings, and will usually not look right - it's best to just live with this than to constantly readjust the TV. There are also DVD's available which walk you through proper TV adjustment.
Jan 02, 2009 | Toshiba 36AF41 36" TV
SONY PROJECTION TV (SXRD) KDS-R60XBR1 AFTER ADJUSTING COLOR FOR BEST FLESHTONE THERE SEEMS TO BE A DOMINANT SHARTRUSE (YELLOW GREEN) CAST TO THE WHOLE PICTURE. IT IS NOT AN EXCEPTABLE QUALITY OF...
You have a bad optical block. Sony is aware of this issue and has extended the warranty to replace this part. You can find out more by pasting the following address in your web browser:
Dec 10, 2008 | Televison & Video
Sony 50" SXRD Wega
There should be a display button on your remote. Press it and it should turn off.
Jul 09, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
SONY KDSR-60XBR2 fleshtone green & yellow
don't placed any magnetic materials around your tv
Jun 27, 2008 | Televison & Video
Connecting PC to sony SXRD with RGB cable no display?
How are you connecting the PC to the TV (ie which input and what type of cable are you using?)
Aug 12, 2007 | Sony KDS-R50XBR1 50" HDTV
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
