My tv keeps cutting off after about an hour - Televison & Video
  • 905 Answers
Its over heating and causing failure of some component that will need to be tested to find it
Posted on Dec 10, 2008
Celcus tv sound cutting out
Gate7, your main board in the TV may be bad and may need to be replaced. Try this RE SET procedure first, turn the TV on so you have a picture,then
while it is on unplug it. Wait 5 mins and plug it back in.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 26, 2016 | Celcus Televison & Video
Why is my sagem recoder keeps cutting off, what is wrong with it.
It probably needs some capacitors replacing in the the power supply unit (PSU).
Jul 13, 2014 | Sagem PVR 6280 Freeview DTV Receiver /...
The tv keeps cutting off. I have checked to make sure that the sleep and timer is oof but the tv still keeps cutting off. it cuts off sometimes every 5 min, and sometimes every hour or two.
Hi William,
If you have necessary tools and test instruments, and know safety precaution in basic troubleshooting, I would advice you to check/replace the electrolytic capacitor in the power supply section, this cap malfunction and produce out-of-regulation which sense by the feedback circuitry and turn the unit into subsequent shutdown. Also, look for a bad solder joints on the board., it will do the same thing. Secondary reasons of symptom is Voltage Regulator IC, and microcontroller circuitry.
If you can't do the job yourself, I would advice you to look for a technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 17, 2011 | Toshiba 27AF45 27" TV
New 42" HD TV ought
Don't mess about with it. Get it replaced under warranty.
Dec 19, 2010 | LG 42PX5D 42 in. Plasma HDTV
My sony wega keeps cutting off then coming back .
a couple of years old can be a long time:
has the TV been on 24\7
It's the amount of hours that matters..
electrolytic capacitors typically last 3000 to 5000 hours....
Special "long life" caps last close to 7000
but the caps in most consumer electronics, even broadcast equipment 3-5K hours.
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
It just won't keep running after running fine a while.
PROBLY NOT TRIP CHARGES ARE AT LEAST 45.00 AND THEN 65.00 PER HOUR PLUS PATS WHICH ARE EXORBENT
May 20, 2009 | Mitsubishi VS-55707 TV
My plasma tv keeps cutting off after about 1 hour and it does not come back on until i unplug it and then turn it back on and press enter
It sounds like your tv is failing. Similar problems have been seen with Philips tv's. tv needs servicing.
May 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Torubleshoot
how to fix a power supply if the white copper is no power
Jun 21, 2008 | Computers & Internet
TV keeps turning off
You must Check Lopt Line output Transformer , Sounds it getting hot , then trip. If you are not a tv tech take it to one because there is heave high voltage there.
Jun 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Is my picture tube going?
Most proj TV's of that type have 3 Picture tubes Red, Green and Blue. It's not likely that all 3 went bad at the same time in the same manner. So I believe you have a circuit problem, probably in the power supply stages, possibly a bad solder joint.
Hope that helps...
Geno
Mar 25, 2008 | Televison & Video
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
