Question about iLO 2600 Television
Lcd ilo 27 inch
Tv message no signal has a 3 prong adapter outlet nogo tried converting to 2 prong sos please help thanks gee
    Problem Solver:
  • 4 Answers
THE TV 2 HAD TO PUT ON CHANNEL 60/ AIR, SIMPLE FIX THANKS
Posted on Dec 16, 2008
Hi ,iam trying to connect a digtial converter(rca) to a dawoo dtq27u4sc 27'...i read your info.what kind of transformer(if any) do i need.. ? iam using the 3 prong av cabel hook up at back of tv = av1...
OK, let mesee if I get this right, you have a digital TV tuner box that picks up the digital TV signal off the AIR? And this tuner box has 3 RCA jacks on the back (Red:Right channel audio output, White: Left channel audio output, Yellow: Composite video output)?
If the above are corrects, then all you have to do is to connect those cables to the AV1 (if AV1 is for the compoite video and analog audio input). No transformer needed.
Please clarify.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Please leave rating if it helps.
Jan 16, 2011 | Televison & Video
Who is the manufacturer of the ILO 26HD Television?
the manufactured should be on the back of the tv- i have an ilo 27 flat lcd hdtv the name on the back is
SUPERIOR ENTERPRISES
5900 CANOGA AVE
WOODLAND HILLS CA 91367
Mar 15, 2009 | iLO 2600 Television
Power Cable Replacement
Try ebay. If unsuccessful you may have to convert the plug on your set to a standard one that will work with a normal standard wire.
Jul 28, 2017 | iLO V27DMBX Television
HDTV says "No Signal" when there is one
you may have to go into the menu of the player to change the setting!
Dec 08, 2008 | Olevia LT27HVX 27 in. LCD Television
Thin green line
Most likely your tv has a defective LCD panel. If it's in warranty, drop it to the warranty depot shop to repair.
Jan 18, 2008 | Televison & Video
Screen rolls
I'm writing to you on a screen that is rolling and sometimes flickering right now. I've tried 3 different screens on the same outlet, and they all have the same problem.
1. If you have any speakers near your monitor, try moving them away, this might help because they might not be shielded enough.
2. Try another screen, if the problem persists, it may be your power outlet.
3. If you don't want to spend money on a new screen, spend some time looking for a 3-prong grounding adapter.
I used the 3-prong grounding adapter, those little adapters that plug into the wall using 2 prongs, and then you can plug a 3 prong appliance into them on the other site, and it helped make the rolls not appear as often, and not as dark.
I think it is something with my power or the plug I am using.
Hope this may have helped a tiny bit
Oct 25, 2007 | Acer AL1916W 19" LCD Monitor
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
No signal
Weegee, Unfortunately you are trying to mix two different video types: VGA is an analog video interface found on most computers (except for latest with flat panel monitors, which are usually DVI). Your TV DVI interface is digital (although there is a DVI-A, which is an anlog DVI interface, it is unlikely that your TV has this). So, what you are trying to do probably won't work. I assume your computer does not have DVI output (otherwise you wouldn't have bought the adapter), but some monitors have VGA inputs; does yours? What kind of DVI adapter did you get? Is a DVI-A? Check out http://en.wikipedia.org/wiki/Dvi for info on DVI interfaces.
May 12, 2007 | iLO 3200 32 in. LCD Television
27 inch Digimate LCD TV Shuts Off Automatically
have you had this probelm fixed mine just starteed to do it and its only 8 months old and I cant afford to have it fixed please help if you can thanks
Feb 04, 2007 | Digimate DGL26 Television
Televison & Video Logo
47 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
