Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
White build-up My dishwasher is approx 4 years old. Some of the water spigots were plugged and there was a terrible buildup on other parts
  • 41 Answers
This is scale build up you should run a descaler through your unit if you cannot find any viniger works just let it sit in overnight
Posted on Dec 11, 2008
The trays in my 1-1/2 year old dishwasher seen to be plastic coated. They have now acquired a kind of lime scale buildup. What is the cause or how can I get rid of the build-up
First of all I am not paid to sell product but I can tell you the build up you have is normally soap. You can use vinegar, but I personally use a product called Lemi-shine. I add this to the soap (2 tablespoons) to the soap in the door for every load. This will clear this issue you have and keep the dishwasher clean like the day you got it. If you doubt this check out the Finish website as this will answer the questions you might have. Good Luck
Oct 09, 2014 | Refrigerators
Is it worth fixing a 10 year old KitchenAid Superba side by side?
Pull it out... - turn OFF the water inlet valve..
........... if it still keeps everything cold,,, keep it,,
Jul 08, 2017 | KitchenAid Kitchen Aid Superba Series...
Leaving a white residue on dishes after its full cycle. Have tried different soaps,rinsing agents, and ran it through a cycle with a cup vinegar in it.Is there something I can do to repair this problem ?...
As you have already done the vinegar cycle and all now it must an technical reason.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Mar 17, 2011 | Frigidaire Dishwashers
We have a reliance 501 propane water heater model # 5 40 porto manufactured in 1991 We have had build up of rust in the pipes from the tank to our dishwasher and sink. Our dishwasher is not cleaning...
After 18 years there will be a build up . you could flush the tank and see what comes out, replace the line to the sink and dishwasher , then you can decide if you want to replace the tank .Which sounds like it will need to be done .
May 13, 2017 | Water Heaters
My dishwasher smells
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removed) this will expose the pump impellor and you can check for any obstruction.
Try running a 65 degree wash with a couple of caps of baby sterilising fluid. If the d/w is connected directly to the sink, remove the spigot and check there aren't any blockages. I run a dishwasher cleaner thru my d/w every 3 months and every couple of week I will load the machine for a wash, add tab to dispenser and just after starting a 65 degree wash, I will open the door and tip in approx one capful of sterilising fluid.
baby fluid is also good as a sluice wash for your washing machine on 90 degrees (w/m empty, approx every 4 weeks).
ps I appreciate the link is not for your model but the part placing should be the same.
I hope this helps, Good Luck.
Jul 11, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My Jenn-Air dishwasher is approx 15 years old. Now all of a sudden it's leaving a white film on everything. I've tried both liquid and dry detergents as well as jet dry, running the hot water and disposer,...
it is not your dishwasher actually. it is your water. they must have changed the way they were treating it in your area. hard water leaves this white film. has a new product out exactly for this problem. it is very affordable and works amazing. you will love it guaranteed.
Aug 09, 2009 | Dishwashers
4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Jul 26, 2009 | Bosch Dishwashers
Hi, We have a new whirlpool dishwasher type no. 575-0. GU2275X TVQO. We have not been able to get clean dishes since purchase. Water is hot, everything seems to be operating smoothly. Use the...
I think I can help. We have the same dishwasher and we have very hard water. The dry powder detergents don't work well. We have found Cascade All in One Gel detergent works best and we use only a little; don't go beyond the first mark in the detergent dispenser, regardless what the instructions say. We have found using more of any detergent makes white film. Don't fill up the pre-wash side either. The Cascade All in One Gel does both at one time, so no need to put some in the pre-wash side. Also keep Jet Dry in the rinse dispenser and make sure it is set up higher, turn the arrow to 4. Try that and move up if needed. Next, we put half a cup of white vinegar in the dishwasher, just pour it in the bottom each time, right before we wash the dishes. This works GREAT! We used the white vinegar in on our former dishwasher of 9 years and never had any trouble with any film buildup. The vinegar cuts all the film and makes glasses look terrific.
If you are still are having trouble, cut out the Heated Dry at then end. The heat can cake hard water on your dishes. It may not dry the dishes as well, but it seems to stop any buildup. Using the vinegar though, we use the Heated Dry and still have no film buildup. So for us, we use a small amount of Cascade All in One Gel detergent (buy this basic gel, no added anything), 1/2 cup white vinegar poured in the bottom and Jet Dry in the rinse dispenser. We always have sparkling clean dishes with no hard water buildup. If you don't have real hard water, but just a little hard water, you might try decreasing the white vinegar to 1/4 cup and increase it if you start seeing the white film build back up. Also don't overload the dishwasher. Make sure there is space in-between each dish and have all plates face toward the center.
Make sure you turn your sink faucet on to as hot as you can get it and run the water until it is hot, then turn off the faucet and turn on the dishwasher. This helps to keep the dishwasher from running longer, which would mean more hard water swishing around longer if you don't heat the water, and you know what that means, plus the heating element has to work harder to get the temp up and that makes it burn out quicker. Once a month check your jet sprays, that turn around in your dishwasher, because the little holes can stop up with hard water gunk and this will cause film on your dishes to build up. Take a toothpick and crush the gunk in any holes and make it go out of the holes. Hope this helps you!
Apr 27, 2009 | Dishwashers
Soap left in cups when cycle is over
If the problem is that the dishwasher isn't filling with enough water, you should replace the water valve.
If it's getting enough water, but dishes have a white film on them or are still not getting clean, you may have hard water build up in your machine. Try to run a dishwasher cleaner thru it, or depending on how much buildup you have, you may need to take the dishwasher apart and clean it. I know JetDry puts a cleaner out, but I haven't personally tried it yet.
You can usually see white buildup inside the dishwasher if this is your problem.
Apr 07, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
New dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at
Sep 06, 2006 | Kenmore 13869 / 13864 / 13862 Dishwasher
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
134 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
