Tv has sound, no picture besides menu options and volume control
I have an older tv and it went black the other day but i still have sound and the only graphics that show up are the menu options and the display.
sometimes it looks like it is almost going to start working but doesnt.
  • 899 Answers
You will need to have this repaired , it may only be a small component or two that are failing , but this does seem like one of the common component failures , testing and or research will need to be done
Posted on Dec 10, 2008
How to repair LG LCD TV 47LG70-UA no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 12, 2016 | LG Televison & Video
TV wont respond to the button controls (Cant find the remote)What do you suggest?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 21, 2015 | Televison & Video
Cat stepped on remote TV went black have sound but no picture i have tried every menu option?
Try doing this:
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control
for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote
control for more than 3 seconds.
9.1.2. Exit
Disconnect the AC cord from wall outlet.
This is straight out of the service manual.
Regards,
Joseph Van Buren
Aug 01, 2014 | Panasonic TH-42PX75U 42 in. Plasma HDTV
I have an older model sansui tv with out original remote. Somehow captions were turned on and I can't figure out how to turn them off. Help asap!
Ur tv have a button that said Menu on the bottom tv beside buttons only said POWER,CHANNELS + -,VOLUME + - ?Used the tv menu button go through the options functions look for Close Caption find CC 1,2,3 or TEXT 1,2,3 turn it all off,will stop captionning,if tv have no Menu option button.The captionning can be turn off by an original remote only.Try website like Remotes.com to buy the tv original remote.
Apr 27, 2011 | Televison & Video
No control and the picture is too dark
Not sure what you mean by no control?
Brightness settings on any TV made since the early to mid 90's (besides tiny cheap B&W TVs) will have the settings in an on-screen menu. Sometimes the menu is accessible through buttons on the TV itself, but always accessible through the remote control. If your TV does not have the ability to get to the settings menu from the TV controls itself, you will need the original (or compatible) remote control for the set, there is no other option.
It could also be that the set is just dying; it's an older set, and certainly would be a possibility.
Nov 14, 2009 | Sharp 25N-S100 25" TV
Was watching TV and the picture just went black (still had sound)
eithor the flyback just craped out or the tube went
try turning up the flyback failing that call a service tech and ask for a quote
quote cose 30-50 bucks
atleast you will know forsurre if it's worth fixing
Aug 06, 2009 | Samsung SPN4235 42 in. Plasma HDTV
LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Apr 10, 2009 | LG 32LB9D TV
32 Inch Brand new Samsung 32" LCD showing subtitles / no volume??
I had a similar problem, checked all of the TV's control settings only to find out that my cable box had an independent "mute" function that automatically turned on the closed captions when activated. Once I found that and turned it off, all was fine.
Mar 18, 2009 | Samsung LN-R237W 23 in. LCD Television
OLDER MODEL RCA HOME THEATER PICTURE AND PICTURE
Hi Unykue,
I am an electronics technician who just happened have been given the same set as you because it was giving the previous owner the same problem. Since I am confident in my trade, I took the set and diagnosed noise in the remote receivers input to the cpu.
What this means is that a capacitor( or something) wasn't working properly and was either not filtering the noise out or it was introducing noise into the data stream that controls the TV through your remote control.
My fix was to essentially cut out the entire remote control input to the TV. Since I have a directtv box to give me remote control, I don't care if the TV's remote works anyway.
The way I did this was to open up the unit and find the front I/O board were the buttons meet the switches for power,chaennel, volume, etc. On that board there is a plug with white wires and one black wire. The two wires to cut are the one next to the black wire and the one all the way at the other end of the black wire. These two wires are easy to splice back if you do not like the results of this procedure so that there is really no risk of damaging your set. If you wish to verify the proper wires to cut, they are the two wires that come from the IR receiver's side of the board YET DO NOT GO TO THE OTHER SIDE WITH THE BUTTONS! There is one wire that does indeed go to both sides.
This may not be a perfect solution but it is free. I hope that this will help someone out there.
Len
May 09, 2008 | RCA F32648 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
