Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips Projection picture
My picture lines bend down to the bottom corners of the tv. I was told that one of my bulbs might be out. Is that true and if it is how can I tell?
    Scholar:
  • 87 Answers
You have bad convergence amps, tubes are fine unless you had a hazy looking picture before the convergence went out.To fix the haze the fluid in the picture tubes would have to be changed out.
Posted on Jan 12, 2009
I have a 57H84 toshiba I bought new in 2004 I have lines from top to bottom approx 1 in apart.I have been told that is the bulbs that need to be cleaned .Can you tell me how to get in to the bulbs and...
57h84 IS A REAR PROJECTION SET WITH 3 picture tubes.
you got lines in picture top to bottom on the screen running left to right?
They go away after a while?
Apr 26, 2012 | Toshiba Televison & Video
The picture bends at the top and the bottom of the screen and is blurry where it bends at
The tv have a problems known as a convergence problems,it dead.Tv have colors R,G,B lines mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
Projection lights don't line up
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
Apr 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Color lines in tv screen
it's an lcd filter fault it's betwine lamp and screen before mirror, seems like u will need to replace it but it hard to say without look at it.
Mar 22, 2009 | Philips 55PW9363 55" Rear Projection...
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
Bent Picture at top and bottom
You have bad convergence amps.The fluid may need to be changed if the picture had a hazey look to it before the convergence went bad.
Dec 13, 2008 | Philips 60PP9202 60" Rear Projection...
Philips Blue Shadowing
If you have not already done so go into the picture menu and set the convergence. The convergence is the angle at which the three picture tubes meat at a given distance. The tv will have at least 3 and up to 64 convergence points, and those 64 can be set for all three colors. This can be tiresome but I'll be it will solve your problem. What your trying to do is get the color in the cross-hair so you cannot see the color behind the target. On top of the fine setting for each point and color you will probably have 3 gross adujustments for blue and green and maybe red. These adjustments will affect positioning, like what you are discribing. You should do this at least every month, the thermal cycleing of the lamps is what will cause this to creep out of adjustment.
Sep 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox big screen problem
Its not the bulb.
When it comes on is it real bright?
Did you loose the audio also?
Any other symptoms prior to having this problem?
Aug 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Warping
If this is a projection tv then replace convergence amps. and resistors in the area also look for open fuses.
Sep 05, 2007 | Philips 55PP9352 55" Projection Television
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
