Question about Toshiba 36AF41 36" TV
The Contrast and Brightness on tv appears to be dark.
I own a 36" toshiba 36AF41 standard tv and the problem I'm having is, just recently I've noticed the picture on my tv was quite dark. When I went to make the proper adjustments, there wasn't any change in the color or the brightness. I turned the color and brightness all the way to 100 and the picture appeared to be bright for the moment, but it seems dark again. What seems to be the problem here? Do I need to get the tv repaired or would this be a do it yourself fix?
    Scholar:
  • 51 Answers
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Posted on Jan 02, 2009
TV brightness problem
Please view my Tips & Tricks. I have a tutorial which will help you correct this problem. Your Screen Voltage is too low. You will need to take the back of the TV to fix this. It's not hard, just be careful... the TV must be powered on during the adjustment. I hope this was helpful, best wishes.
Apr 17, 2010 | Toshiba 36AF41 36" TV
Contrast & brightness is at 100% and picture is still too dark
If it can't be adjusted you have a problem with the biasing circuitry. Probably a bad bais IC resistor pack.
Mar 09, 2009 | Toshiba 36A40 36" TV
Toshiba 36AF41 36" TV no red color
Go to your menu/settings from the remote (or buttons on the tv, if applicable). And find the color or saturation settings, play around with those. If that doesn't work, your tv is dead, get a new one.
Mar 07, 2009 | Toshiba 36AF41 36" TV
Toshiba television is black picture
If this just happens while vcr is playing. Check the vcr. Did you happen to adjust its brightness and contrast settings. If things doesn't change. Then if this model is a crt type could be adjustment on its flyback transformer is needed tweaking slowly its screen knob or tweaking also its focus knob until you got it to the level of viewing it correctly.
But be aware, hazardous voltages inside it. Or let th technician set it for you, its a minor adjustment.
Jan 09, 2009 | Toshiba 36AF41 36" TV
Brightness and color
It really depends on what YOUR eyes are pleased with - if 50 looks good to you, that's where it should be. It seems like you might be afraid of messing up something - don't worry, you can't hurt the TV by adjusting the customer controls :-) You might try a little experimenting - kicking them up to 75 might give you a brighter and more pleasing picture. I've been a TV technician for years, and I generally like the brightness and contrast up almost to the maximum (I like a bright picture as opposed to a "warm" one), with the color and hue adjusted for an accurate reproduction of facial tones. But the bottom line is what YOU want - feel free to experiment, you can't hurt anything as long as you don't start taking out screws :-)
Jan 02, 2009 | Toshiba 36AF41 36" TV
Well i really want to know what level the coular and brightness lvel has to be on a toshiba t.v
You can set these controls to your liking, though a lower brightness setting might increase the life of the screen. First, set the brightness and contrast to a level that is pleasing to the eyes, then adjust the color to look realistic - enough color without being disturbing. If faces area look greenish or purplish, then also adjust the tint (sometimes called Hue) until you get accurate flesh tone. Flesh tone is the best thing to adjust for; when you get good flesh tone, the rest of the picture will look great. ALWAYS make adjustments during a live news broadcast, which tends to have the most accurate balance of brightness, contrast, color level and hue. Note that commercials are all recorded in different studios with different settings, and will usually not look right - it's best to just live with this than to constantly readjust the TV. There are also DVD's available which walk you through proper TV adjustment.
How do I fix contrast and brightness on 36" toshiba tv?
you can bring more brightness by removing cover on your tv and then you will see ther 2 button ther in back of your tv one is FoCUs and other is G2 rotate the G2 button till you see more brightness on your screen put the cover back and that is if you dont know to do that go to one authorised service
Dec 10, 2008 | Toshiba 36AF41 36" TV
Tv sensor for remote doesnt work
1) solder bad connects on remote sensor mounted to front edge of circuit board or, if necessary
2) Replace sensor Tosh # 23009490 ...........................T.
Jan 08, 2008 | Toshiba 36AF41 36" TV
TV picture is dark
the unit flyback has 2 adustments most likly one is focus the othercontrol on the unit g2 which if slightly adjusted will bump ur brightness up
Oct 27, 2007 | Toshiba 36HFX72 36" TV
Toshiba 36AF41 36" TV Logo
241 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
