Question about Kodak Easyshare Printer G600 Thermo Printer
Will not pick up paper
Unit is about 1 1/2 years old. It shows paper out or will not attempt to pick up the paper at all. You have to power unit off several times before it goes through the start up cycle than hand feed the paper. Any ideas or fixes out there???? Any thing better on the market?
Take a wet cloth and clean the front grabbing roller by rotating roller on the wet cloth. You may have to do several times and after printer has not been used for a while.
Posted on Apr 15, 2009
My Kodak Printer Dock Plus has the same issue.  It appears that when you leave the paper in the paper tray for long periods of time, the first sheet it would pick up becomes "slippery" to the pickup roller. I remove the paper and turn it 180 degrees before putting it back in the tray, and it usually picks up the other end no problem.  If that doesn't work, then I rub the end of the paper on my shirt, and that usually cleans enough dust off that it works fine.
Posted on Dec 25, 2008
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Doc feeder jam error on HP laserjet M1522nf continuesly also due to that i am unable to scan and also its showing that "Device is busy try again later"
Open adf cover, remove adf pick up unit, two sensor located in it 1. paper leading edge sensor, located upper portion of the unit.2. paper out sensor located back side of the adf pick up unit. Carefully open this unit your will easily find out the sensor location..
Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
My HP4100 DTN is continually having paper jams for no obvious reason. What can I do to resolve this? (I mean, I know how to resolve the jams, but how can I make sure it does not jam all the time)
Old age printer, prepare to replace the parts.
Step 1: Clean all paper path sensor, replace paper pick up rollers, seperation pads, check with out duplexer unit..
Step 2: Even paper jamming replace fuser assembly..
Step 3: Check with duplexer unit, clean deolexer sensors & rollers..
Nov 23, 2010 | HP LaserJet 4100dtn Printer
Wbr1310. i switched laptops to mac. it picked up the old settings but now it's not picking up the password etc. what do i do? i do not have the set up cd anymore. can you plse help me? thanks
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
I have a pixma 190 all in one showing E3 which is a paper hang. I have turned off and restart, unpluged and repluged with no results. How do I get paper hang up out to use the 190? This unit was purchased...
There are many places for paper scraps to hide, and a sensor in the white guide behind the platen roller that gets bent. You get 1 year warranty with Canon printers and you can call 1-800-828-4040 to find the nearest shop.
Dec 24, 2009 | Office Equipment & Supplies
Not picking up paper
The roller can be replaced, #JC73-00239a, a little tricky to get the old one off and new rubber installed, but much less than a new printer.
Nov 23, 2009 | Samsung ML-2510 Laser Printer
Paper jam E
There are two main causes of this error on C11's. Firstly does the paper get picked up and partly fed when you try to print?
If the answer is yes then it is likely that the sensor actuating arm on the transport unit has been unseated, a common occurence. To check for this, open the back cover and feel if the actuating arm springs back when pressed. It is located centrally about one third way up the black plastic transport unit. If it is missing/loose then you will need to remove the transport unit to reseat it.
If the paper does not get picked up at all then it is 99% likely to be a faulty solenoid which is also very common on this model series. This can be very complicated and will require a replacement solenoid to hand before you start.
Let me know which of the above it is and I will give a detailed description of what is required.
Jan 21, 2009 | Epson Aculaser C1100 Printer
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
Kodak Easyshare Printer G600 Thermo Printer Logo
342 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
