Question about Hitachi 53UDX10B 53" Rear Projection Television
Top left of tv swoops down, red and green
Can it be adjusted? please help!
  • 905 Answers
This is the convergence IC's that will need replacing and the resistors on them will need to be tested
here is an example of the convergence IC's http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
Posted on Dec 10, 2008
How to fix alinment
Bad convergence ic's. STK392-110 an open 2.2 or 3.3 ohm resistors.
Nov 05, 2011 | Hitachi 43FDX01B TV
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
There is a yellow ''swoop'' in the upper left portion of the tv and shadowing. The ''magic focus'' does not resolve the problem. When I try to adjust manually, the grid shows arched lines (''swoops'' along...
Sounds like you have a bad convergence circuit, it's what lines up your picture so the colors are correct. Most brands (excluding RCA) use the same basic design. There are 2 big ICs called STKs that normally fail, some resistors or fuses may also go. Its about $300-$400 bucks to have someone repair it. If you want to try it yourself, this link TVrepair will take you to a site that sells kits with the parts and step by step instructions on how to fix it. Good luck
Mar 06, 2010 | Televison & Video
The rca 52 inch tv turns on with picture but the images are in split in three with red green and blue and theres about five lines that swoop down and up to the top of tv ?
the ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com usually repairs that issue. The kit contains the parts and the CD with instructions
Oct 30, 2009 | RCA D52W19 52" Rear Projection Television
Distorted screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Sep 10, 2009 | Samsung HL-R4264W 42" DLP HDTV
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Sony kds-r60xbr2 televison
Make sure that you do not have a magnetichc feild around the TV.
Sep 06, 2008 | Sony KDS-R60XBR2 Television
Top left corner double picture red and green
you have a failed IC resistor usually you can physically see the bad one because it burns out leaving you to guess what the value was. Hitachi offers a convergence fix kit which has 2 IC's and all approiate resistors.
Sep 01, 2008 | Hitachi 43FDX01B TV
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
Swoop of red coming down from left
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 05, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
