Question about Toshiba Satellite 1405-S151 Notebook
I want to upgrade the memory to 1GB.
I have 2 512 memory chips and when I install them I get an exception error (select = 0048H offset = BDD4H). It will boot to windows XP Pro with one of the chips but the I get a "Blue Screen" and it restarts. I flashed the BIOS with the latest one I could find a Toshiba which was dated 12/17/02. Can you help? Thanks, Chas
  • rmherndon Feb 23, 2009
    I had a 512MB and a 256BM stick in my 1405-S151 which made it run at 768MB. The documentation online said it can run at 1GB. So I ordered another 512MB stick and when I installed both of them, the laptop beeps three times. What does this mean? If I try both sticks one at a time, they both work. I'm at a loss.
According to this pc can only take 2 256mb chips for 512mb max. i'm looking for such a chip right now and stumbled on your post
Posted on Jan 23, 2009
My e-machines will not let me upgread my ddr2 1eb memory
That Machine would take DDR2 PC2-5300 upgrade chips. The max that system could take would be two 1GB sticks for a total of 2GB or 2048MB of memory. Memory is fairly easy to damage with static discharge and is also very easy to not put in all the way. When putting it in, unplug the power from the computer, push and hold the power button for 20-30 seconds to help discharge power from the computer, Line up the pins on the memory and push them into place till the little arms at the sides of the slot pop up and click into place. I'd install one chip at a time, powering the machine up after the first chip to make sure it works, then starting over again. The only time I'd install both chips at the same time would be when installing a memory kit (two or more chips in one package), in which case, install both chips before powering it on.
Jan 13, 2013 | E-Machines T5082 PC Desktop
Fujitsu v700 4 gb memory will not boot
You don't say if the Notebook is 32 or 64 bit.
If its 32 you may have a problem uprating the RAM more than be handled.
Aug 03, 2017 | Fujitsu LifeBook V700 Notebook 15.4...
Can I upgrade memory to only one gb of memory or install 2 512 mb on a toshiba satellite m35x series
Looking at the specs, the max is 2gb for your Toshiba. According to this website, its only a 256mb ddr sdram. So my guess is you only have 1 slot for the ram. I'd go with a 2gb ram if you can afford it, 1gb just don't cut it in todays technology.
I believe its the PC2700 model, so find a 1gb or 2gb PC2700 @ 333mhz and you should be set.
Sep 09, 2009 | Toshiba Satellite M35X-S114 Notebook
Can I add 1GB memory chip in 2nd slot with a 512MB chip in 1st?
You can upgrade by inserting a 1GB PC2100 DDR SDRAM DIMM. I would put the 1MB in the first slot and move the 512MB chip to the second slot.
The 1GB should cost around $40.
Jul 05, 2009 | HP Pavilion 763n PC Desktop
Upgrading memory
hi If you go to they will scan your pc & tell you what rams youhave & what you need. then buy from wherever. hope this helps blue51
Apr 14, 2009 | Dell Dimension 4600 PC Desktop
Olympus c-740 reads card error when 1gb xd memory
its non supportive to 1gb card as you will have to get the device upgraded to make it support 1gb.
Mar 03, 2009 | Cameras
Plenio GPS 3000
Plenio Is Litttle Picky On What SD-Chip To Use, I Just Upgraded Mine To 2GB SD-Memory
Chip Purchased From Walmart, Mgr Name Is a PNY, Black and Gold Display Case, also
Say's OPTIMA SD Ultra High Speed, Mgr Bar Code# P-SD2GB-FS [On Back Of Display Case]
During My Upgrading to 2GB Chip, Using Plenio-OEM CD," Navigation Map Data Base" DVD-ROM
Version 4.0. Had same problem,
Using Plenio Folder on PC " C:/Plenio/V-Up Pro 3000/VUPro3000.exe, checked box, SYSTEM UPGRADE, Selected SD Memory Drive, [My PC Was F:/], then software should detect SD-Chip
and Display Free memory Size, If So, Then Select Next, Should Take Aprox 20 minutes to Complete
Installing Plenio Software From Your PC to SD Memory Chip.
I'am Sure That IS How It Went For You, Mine Did Not Work For Navigation Either, Everything Else Was OK.
Take Your 1GB Chip And Copy To Your Hard Drive, ie; C:/Plenio/OEM_Plenio_1GB_SD
[Good To Always Have A OEM Backup]
From Windows Explorer Locate This Folder Name On The 1GB SD Chip Directory: MobileNavigator.
In This Folder, Locate File: Device.cfg & MobileNavigator.exe & rdat [No File Extension Displayed]
1] Copy These File's To Same Folder On Your 2GB SD Chip.
Your System Now Has Knowen Operating System Installed and should work like before,
might want to recheck your personal setting's.
I also noted using Plenio Software, I could not Check-Box "OS Upgrade" I think this is why
It Did Not Work. Still have to ask Plenio-Tech About This.
Contact Dan Kim [USA] 408-970-3388 office
I also Noted CD I have Installed Larger Map File Size Than The Preloaded 1GB-Chip Has On it.
located in the "Cities" Folder, file: iusa_110mb_en_standard_cg.cdt 114,232KB
CD Ver 4.01 Installed this File; iusa_180mb_en_cg.cdt 184,145KB
Also Came Up Somewhere With Plenio a: iusa_50mb_en_cg.cdt 48,258KB
I'am Not a Plenio Tech-Rep Just A VXA-3000 Owner
Also Installed 103 MP3's and 20 .bmp Pics/Slideshow, had 480KB Free Memory Left
Aug 02, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Most newer laptops have easy access to their memory slots, I'd recommend you got to the manufacturer's website and look for the maximum memory your system will allow. If you look at the bottom side of your laptop, you may see several small covers with just one or two screws in them. One of them will be where the memory slots are. It is not uncommon for the laptop to have a very small 'memory chip' icon on the cover. Be aware that many laptops only support two memory chips, and may have both filled already. For example, if laptop has 512MB memory, it may have two x 256MB chips in it. Which would mean, that to upgrade to 1GB memory, you would have to purchase two x 512MB chips. or one 1GB chip.
Jul 27, 2007 | Toshiba Satellite L10 Notebook
Toshiba Satellite 1405-S151 Notebook Logo
189 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
