Question about Sony ICD-P210 Digital Voice Recorder
MY SONY ICD-ST10 RECORDER IS STUCK WITH AN "ERR ACCESS" MESSAGE
I change the batteries (which should solve he problem according to te manual) and NOTHING! THe screen's "ERR ACCESS" mesaage is stuck there forever
  • 1 more comment
  • gmarkie Dec 26, 2008
    err access, can't do anything; changing batteries doesn't fix problem.
  • Anonymous Jan 08, 2009
    the memory needs to be reformatted, but according to the manual there's no way for a user to do this. so it looks like we're screwed unless someone knows a way....
  • shuddermouth Feb 05, 2009
    has anyone contacted sony about this ?
I try this solution but it didn't work! I can select WHOLE but I can't select DELETE from the menu.
How can I do for restore the data storage or for delete all and formate the IC recorder?
Posted on Apr 11, 2010
I have stupidly deleted all files off my Sony Ic recorder (everything).. now it is showing err format.. help
How do i restore original files?
Posted on Oct 26, 2010
    Problem Solver:
  • 5 Answers
Your problem may have been caused when you removed the unit from the PC without using the "safely remove hardware" option.
What you need to do is download the latest version of Digital Voice Editor (I think we are up to 3.1 now)
When you connect the ICD unit it will probably give you a number of access errors
Ignore them and go to the IC Recorder Menu. Select WHOLE and DELETE. Delete everything.
After a minute or so the unit will come to life and you'll see the Directories that are standard in your unit.
Remove the hardware from the computer (safely! by closing the program first) and tirn the unit off.
Now turn it on...... Bingo!
Posted on Mar 11, 2009
I have a Sony IC recorder ICD sx25 and I am getting an "Err Access" message on the screen. Any solutions?
HI,
The battery indicator will flash and/or the IC recorder will display the error ACCESS when the batteries are low. Install new, fully-charged batteries to resolve this issue.
Regards,
Bilal
Oct 09, 2013 | Sony IC Recorder
I have sony icd-px820 voice recorder and i'll format it through PC and now its show a err call "err format" what can i do plz help me.?
You have to format it as FAT, not FAT32.
Then safely eject it from your system and unplug it. It will say ACCESS for a while and then be back in function.
Good luck.
Apr 19, 2011 | Sony ICDPX820 (2048 MB 5355 Hours)...
I have just acquired a Mac Mini and want to find drivers for: 1 - my Cannon N656U scanner 2 - my HP LaserJet 1100 printer 3 - my Sony digital recorder ICD ST10 Thnak you for your help :o)
You'll be very lucky. MAC mini and windows CE are very reduced operating systems with low/restricted memory.
Mini's are only configured for the basic of needs most being internet connections.
Dec 23, 2010 | Computers & Internet
Access error, new batteries don't help
From Sony Help... Error: ACCESS
Solution:
NOTE: Be sure to install the type of batteries specified in the user manual. Manuals are available online through the Manuals/Specs/Warranty link on this page.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
Keep us updated.
Dec 11, 2010 | Sony ICD-P210 Digital Voice Recorder
Sony IC Recorder icd-p210 how do you turn it off?
The hold button on the right hand side . Just slide it forward and it will go off. forward means if you are holding it, in your hand facing your slide it up ..
Sep 09, 2008 | Sony ICD-P210 Digital Voice Recorder
Getting My Mac to Recognize the Sony IC Recorder
you can only download it on windows and save as.wav and then copy it on the Mac. I couldn`t find any other way
Apr 08, 2008 | Sony ICD-R100VTP Handheld Digital Voice...
Sony ICD-P210, ERR ACCESS message
Remove the hardware from the computer (safely! by closing the program first) and turn the unit off.
Apr 01, 2008 | Sony ICD-P210 Digital Voice Recorder
My IC recorder P210 says ERR ACCESS
Feb 26, 2008 | Sony ICD-P210 Digital Voice Recorder
Digital voice recorder completely 'locked-up'
Any time an electronic device lockup there is two main reasons. The first is a data error. A data error happens when incorrect digital information enter certain IC chips, and cause the chip to lock up. This is sometimes called system busy. Similar to when a computer freezes up due to corrupt software or a computer virus. To fix you remove all power to the IC chips. Removing the batteries is not enough, due to the fact that circuit boards have components on them that hold voltage. Additional batteries, coils, capacitors. You have to remove the covers and take the main digital board out. Check to make sure there is no other battery on the board. Some boards have an additional battery source for storing date and time and other info. remove that battery. Either short all capacitors and coils. or let them dissipate, sit for a day of two . Install board back in machine this should clear any system busy type problems. If the problem remains, the digital IC chip or chips are bad and have to be replaced. So boards may have a way of reset the circuits. A technical manual or a call to tech support is required.
May 04, 2007 | Sony ICD-B200 Digital Voice Recorder
Err access
i have this issue more or less whenever i change the batteries, i use rechargeables and i think that may be part of the issue. anyway... as silly as it sounds i just keep taking the batteries in and out and messing around swapping them with AAAs from other gadgets that i have and eventually the device works again and all my recordings are still there.
it just happened again this evening, when i put 2 newly charged batteries back into it after them being out for about 24hours.
i messed around with combinations of flat rechargeable and alkaline and charged batteries and eventually it worked again, when i used a charged and an almost flat rechargable combo. i mustve put the batteries in and out about a hundred times but it does the trick in the end.
oh, i have a ICD P520 by the way, but i think theyre all the same. and i have to agree with that other pointless post, what a load of ****. you shouldnt pay this much money for something that doesnt work properly.
goodluck.
Feb 09, 2007 | Sony ICD-P210 Digital Voice Recorder
Sony ICD-P210 Digital Voice Recorder Logo
1,347 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
