Question about AEG 24 in. Favorit 60870M Free-standing Dishwasher
I have a dishwasher that only works intermitently...
I have an AEG Favorit 60870m sensorlogic dishwasher that operates for only a few minutes before displaying C2 in the programme window. I have removed and cleaned all the bits I can get my hands on!! after which the machine continued to operate for approx 5 mins. Have also tried switching unit off at the mains....once reconnected it operated for 25 mins of the half hour wash cycle, pressing any button or opening and closing the door allows for a further 2 mins of the cycle before C2 appears again. Is this terminal? Or can this be repaired?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Posted on Jul 19, 2010
Why C3 code on dishwasher favorit 5081
Problem with inlet water.
Could be: water tap closed, pressure switch....etc
Dado
Jun 19, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
Nov 09, 2009 | AEG 24 in. Favorit 60870M Free-standing...
AEG Favorit Sensorlogic turbodry
I need to know manufactures year of AEG favorit 80860
Jul 31, 2009 | Dishwashers
Error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
Mar 27, 2008 | AEG 24 in. Favorit 60870M Free-standing...
AEG 24 in. Favorit 60870M Free-standing Dishwasher Logo
1,090 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
