Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Cloths remained wet after spin cycle
I have Ultimate Care II washer (8 cycles, 5 speed, quiet wash). After the spin cycle, cloths remain wet, especially when there is larger load. A repair man saw it and said it is "transmission" problem and is charging $280 for it. Is it worth fixing it or buying a new one? I am quite handy...is it easy to fix? If so, what part should I buy... I didn't see "transmission" in part list. Thanks.
    President:
  • 878 Answers
This is a direct drive washer and the trans is not hard to replace. You want to make sure it is the trans giving you the problem. The trans is covered for 5 years under warranty parts only. Other problems could be a worn spin tube, brake or clutch. Did the washer loose its nuetral drain? If your washer is over 8 years old, maybe it's time for a new one. Otherwise, check out the link for the trans. http://www.repairclinic.com/0080.asp Catriver..post back.
Posted on Mar 01, 2007
SOURCE:
Lsw9750pw3 clothes still wet
If there is water remaining after the drain then the drain pump must be checked. Also check the TILT of the washer and must be inclined to the drain side.
If the clothes are wet then the SPIN RPM is insufficient or the program cycle time is not adequate. Please try with another cycle or check the motor, belt, capacitor as the RPM is low.
Jun 28, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Ultimate Care II, top loading washer. Upon intial start up the machine agitates. During the spin cycle, the cold water remains ON, throughout the cycle. This is leaving the clothes wet...
The timer is at fault.
During the spin cycle the timer should send intermittent power to the water valve. This activates cold to help rinse soap residue from the laundry.
If cold is continuous it means the timer is not breaking correctly.
Feb 14, 2010 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
295 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
