Question about Akai LCT2660 26 in. HD-Ready LCD Television
TV cuts on and color goes off
It has been doing this from the day we got it and all we can do is cut it on and off for about 30min or so and then the color comes back after we cut it on and off for a good little bit
    Scholar:
  • 86 Answers
When you turn the TV on and the color is off, if you were to bring up the TV's onscreen menu, is it in color or is it black & white too?
This will help determine if the issue is video board related or if it is the input/output board.  Since the problem is sporatic, it could be a connection issue and service is likely required.
Posted on Dec 10, 2008
Why does the tv turn off by its self
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 19, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Tv cuts off and on no picture or sound
Most TV shut downs like this are HEAT related.Try increased cooling with a fan blowing into it to test this on yours.If it works leave the fan running or repair with a nice little but strong computer fan placed behind the unit..
Aug 17, 2009 | LG 32LG30 32 in. LCD HDTV
Dryer heats up then cuts off
Replace the high temp cut out switch. It's probley not resetting properly.
Mar 23, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Cuts off
Hi, tough question, could be lamp, lamp circuit is overheating,t-con module or you have a bad color wheel, the latter usually causes a hi pitched squeal periodically, you have 2 choices, 1. try replacing the lamp 2. call a tech and let them diagnose it, too many possibilities without doing some diagnostics, video-tek
Feb 03, 2009 | Samsung HL-67A510 67" DLP HDTV
Problem with my Aquos lc32d40u
Your inverter/lamps are bad. Those are only available with the LCD panel as an Assembly, and that is worth more than the TV.
Mar 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
COLOR PROBLEM
your tv need a reheat.reheat from video chroma to crt board
Oct 16, 2007 | JVC AV-27530 27" TV
Tv will not cut on
there is no recall on sharp tv that i know about if your tv is still on warranty take it back to the supplier.if the warranty is finish call a tech the tv has a problem in the power supply and related circuit.good luck.
Apr 13, 2007 | Sharp 32C241 TV
Akai LCT2660 26 in. HD-Ready LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
