LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
Dear sir,
My Monitor powers up fine. No picture in vga or dvi input. Dark screen. Screen equally split into four horizontal zones of different grey shades when switched on. Please help me.
Thank you
  • 60 Answers
Try your monitor to other computer or try other monitor to your computer to see where is the problem
Posted on Dec 10, 2008
What would cause dark blurred display all modes?
I suspect the monitor is dying. Unless it is under warranty, you may need to replace it, as getting it fixed may cost more than a new one.
Jul 25, 2014 | Samsung 22" TFT SYNCMASTER P2250 LCD...
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
I have a 19 inch Gateway HD monitor. The model number is LP1925. When I boot up everything is normal. However, after about 5 minutes the screen goes black. I can't get the picture back unless I pull out...
I see that this monitor has a DVI input, in additon to the VGA input. I suggest getting a suitable cable to use the DVI input, to see if the fault replicates. If it doesn't, you have identified the problem - an issue with the analogue signal processeing circuitry in either the monitor or the computer. The monitor's auto sleep analogue circuitry, for example, may not be sensing a signal, and going to sleep. BTW, if you use a DVI-DVI cable, you avoid the video signal ever going through an analogue stage, and the image will also be purer.
Dec 16, 2017 | Gateway 19" Widescreen Flat Panel TFT LCD...
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
I need to find the VGA controller for the Dell 2005FPW monitor
you can use on all vga cards(you dont need any special controler), this monitor has a USB hub
and its is detected normaly on winxp or above, and the vga cards detect the monitor auto.
i give you the monitor specs, take form website
Display Type LCD display / TFT active matrix
  • Built-in Devices USB hub
  • Width 18.6 in
  • Depth 9 in
  • Height 15.3 in
  • Weight 17.6 lbs
  • Enclosure Color Midnight gray
  • Image
    • Display (projector) image aspect ratio 16:10
    • Image brightness 300 cd/m2
    • Image Contrast Ratio 600:1
    • Max horizontal view angle +88 / -88
    • Max vertical view angle +88 / -88
    Display
    • Diagonal Size 20.1 in
    • Viewable Size 20.1 in
    • Dot Pitch / Pixel Pitch 0.258 mm
    • Max Resolution 1680 x 1050 / 60 Hz
    • Color Support 24-bit (16.7 million colors)
    • Max Sync Rate (V x H) 75 Hz x 83 KHz
    • Video Bandwidth 146 MHz
    • Response Time 12 ms
    • Controls / Adjustments Zoom , Clock , Phase , Contrast , Sharpness , Brightness , Saturation , H/V position , Color balance
    • Display Positions Adjustments Height
    • OSD Languages French , German , English , Spanish , Japanese
    • Display Screen Coating Anti-glare , Hard coating
    • Video Output None
    • Signal Input DVI-D, VGA
    • Features Picture by picture , Picture in picture
    Video Input
    • Analog Video Signal RGB , S-Video , Composite video
    • Digital Video Standard Digital Visual Interface (DVI)
    Audio Output
    • Type None
    Input Device
    • Type None
    Expansion / Connectivity
    • Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI , 1 x Composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 4 x Hi-Speed USB downstream - 4 pin USB Type A , 1 x Hi-Speed USB upstream - 4 pin USB Type B
    Miscellaneous
    • Flat Panel Mount Interface 100 x 100 mm
    • Features Security lock slot (cable lock sold separately)
    • Compliant Standards CE , CCC , MIC , NOM , PSB , BSMI , GOST , SASO , NEMKO , TUV S , C-Tick , TUV GS , EN55022 , TCO '99 , EN 60950 , ICES-003 , TUV Ergo , UL 60950 , IEC 60950 , EN 61000-3-2 , EN 61000-3-3 , FCC Part 15 B , VCCI Class B ITE
    Power
    • Form Factor External
    • Voltage Required AC 120/230 V
    • Power Consumption Operational 55 Watt
    • Power Consumption Stand by / Sleep 3 Watt
    Environmental Parameters
    • Min operating temperature 41 °F
    • Max operating temperature 95 °F
    • Operating humidity range 10 - 80%
    Sustainability
    • EPA Energy Star Compliant Yes
    Feb 13, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
    Black screen with message about no input signal
    might be something wrong with your monitor's data cable
    May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
    When dvi plug is used screen gets funny bright colored lines
    FIX for design fault of ASUS VW222u Problems with monitor using dvi while vga works fine.
    my ASUS VW222u had the same problem many are reporting after about 8 months
    with developing colored "noise" onscreen or dancing red pixels while using dvi but vga is fine.
    luckily my old man is an electronics engineer, rather than be without a monitor since vga still works fine we decided to have a look.
    we worked out the problem. note: this is a fix for the random picture noise problem while using dvi port.
    If monitor works ok with vga but dvi has noise then this fix should work for you.
    1.open monitor (will void warrenty)
    2.unplug all the the cables going to the power supply and dvi port assembly, undo two screws pull down and out you wil now be looking behind the dvi port and be holding a metal module that contails power supply and dvi- and vga port.
    3.you will notice a piece of brass foil joining the earths on your dvi and vga cable this is the problem creating an "earth loop" as both vga and dvi ports are earthed to the metal casing this extra earth is causing the problem introducing noise.
    3.carefully unwrap the brass foil from the two cables and seperate, insualte cables with electrical tape. (wrap around each one seperately they should now be indiivdual cables)
    4.you will notice a silver spring type peice of metal on the assembly that pushes against the
    main body of the unit when re-assembled. scratch the metal with a screwdriver where this peice pushes so you get a good connection when you reassemble it, do not touch as finger grease could screw up the connection. (this step is not vital just a good thing to do why your in there to make sure the the unit is properly earthed)
    4.re-assemble
    enjoy, fixed mine and was quite easy, take care with the plastic latches they are tight - ensure you remove all 5 screws, to see the fifth easily the monitor stand must be removed (two screws then stand slides out from rear of case)
    good luck
    bcmalloy
    Apr 25, 2009 | ASUS VW222U Monitor
    Problem with Interface board or panel.
    Also maybe due to defective powersupply filters.
    Samir
    Dec 10, 2008 | LG Flatron L1710B 17" LCD Monitor
    Power light steady green but monitor goes dark after 4 secs of video
    The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
    Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
    Computers & Internet Logo
    545 people viewed this question
    David Payne
    David Payne
