I start up my pc, starts the booting process, and after it shows the safe mode boot up I press enter, then I lose the picture and the computer is like ded, but, the start button light is on. then it just hangs there for ever and my only option is to turn off the computer using the start up button
SOURCE: MONITOR GOES BLANK
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
SOURCE: Computer keeps returning to "safe mode" options screen
If you choose Start Normal and it boots into safe mode again then you should get professional help if you value any of the files on your computer and don't want to loose any data.
SOURCE: Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
SOURCE: I have a HP Pavilion s7520n PC, it loses video after booting
HPhas provided a patch that prevents this issue from occurring. If yourcomputer has this error, you must first use the steps in this documentto resolve the issue before applying the patch. After the problem isresolved you can install sp37394 - Microsoft Windows XP SP3 Upgrade Utility for systems with AMD processors. Doing so, prevents the issue from occurring again and allows Service Pack 3 to be downloaded using Windows Updates.
Microsoft support article: Youreceive a “Stop 0x0000007E” error message after you upgrade to WindowsXP Service Pack 2 or Service Pack 3 on a non-Intel-processor-basedcomputer (In English)
Also it is applicable for all who are using AMD Processor. The remedy as suggested by Hp is:
Prevent the Intel Power Management driver from loading during system startup:
Step 2: Use Microsoft Recovery Console to rename intelppm.sys If the computer is unable to open Windows XP Safe Mode, use Microsoft Windows Recovery Console:
NOTE:
If desired, you can delete the renamed file "XXXintelppm.syx".
NOTE:
I hope this helps else visit this site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01457284&lc=en&dlc=en&cc=us&lang=en&product=3199127.........sodeep
SOURCE: I HAVE IBM 8305-49U. ALL
Hi
Unfortuantley if you cannot get into safe mode, then windows is stuck ina loop, the easiest thing would be to reformat the machine and reinstall windows
Please leave feedback/vote if my answer was helpful
hope this helps
