My panosonic DVD player will not play a DVD.It displays "0----READ" followed by" H07".
    Genius:
  • 1,199 Answers
Clean lens!
Posted on Dec 09, 2008
Kimi
  • 277 Answers
SOURCE: Troubleshooting -- Displays H07 code
The H07 error message in Panasonic DVDs means problem in the motor. It can be something like "motor isn't spinning-up" or "spindle motor problem". When you call Panasonic, they will tell you that they cannot tell what H07 means until a technician look at it. Obviously, they won't admit it is a known problem. Estimate cost: from $50 to $70 dollar to replace the motor + labor + tax.
Posted on Dec 26, 2005
techman
  • 3130 Answers
SOURCE: Error Message H07 - what is it?
Ho7 is a very common problem with the panasonic dvd players. It means that the spindle motor didnt come up to speed and shut down, Thus the spindle motor needs to be replaced. Good Luck
Posted on Jun 10, 2006
SOURCE: DVD player will not read any disc
SAME PROBLEM EXACTLY
Posted on Aug 04, 2008
  • 175 Answers
SOURCE: h07 code appears on the read out
hi..the reason to this problem is the motor.It may
be either spindle motor problem or the motor is not
spinning up.
check this out..
thank u..
kindly rate my response..
Posted on Jun 09, 2009
  • 112 Answers
SOURCE: H07
Hi i am markus(13) im here to help you with your problem if you open your dvd player and you take out your player i will explan step by step...
1)Open your drive and pull out the power plug then the its open and off.
2)the drawer have a plastick thing on the front pull it up,nou the front cover can get of unclip it and pull of nicely.
3)unscrew the player and unplug nou take it out you will nou see on the top there is two clips,unclip it and then push it underneath and get the laser and moter out gently.
4)there will be a black round thing if you can spray it with selicone spray or put on vasitan.
5)Nou look on the other side of the laser there will be two spots of to soldering points of the thing nou take a battery and a elecktrick cable and connect the cabel with the battery and on the soldering points after 15-30 min turn the cable for about 15-30 min.
6)putt every thing back and that will do the trick.
hope i was usefull for more information about this if you don't understand nice i have pic's plzzz email me to markusmaritz@yahoo.com plzzz rate me tanks
Posted on Dec 20, 2009
My Panasonic dvd-rv32 player (8 years old) functioned perfectly for last 8 years and I cannot get it to PLAY again. I inserted another DVD tonight (actually 3 DVD'S in case the DVD's were defective) and...
Spindle motor/laser assembly is faulty. This part is not repairable - it has to be replaced by an authorised service centre. It may not be economical via this route, since the unit is not a DVD recorder. H07 is an indication of the above issue. Cheaper to buy a new DVD player or recorder than trying to get the faulty one repaired outside warranty.
Jan 19, 2011 | Panasonic DVD-RV32 DVD Player
Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
Sep 03, 2010 | Panasonic DVD-RV62EBS DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Player stops. H07 appears.
This is a problem with the spindle motor,you can locate where the spindle goes into the motor and spray with wd40 leave for a few mins.
Nov 08, 2009 | Panasonic DVD-RV32 DVD Player
Screen says ho7, will not play dvd
This is a problem with your DVD Player .Please call to service center and tell the problem.They may either replace the system or rectify the problem in the same system itself.
Aug 08, 2009 | Panasonic DVD-RV32 DVD Player
REGION UNLOCK
Try this: With "No Disc" on display. Press the following buttons (slowly) on the remote.
PLAY, 2 7 4 2 2 2 2 2 2 0 0 5 2 5 5 PLAY
This is the De-Zone for a simular aged Yamaha Player.
Aug 21, 2008 | Yamaha DVD-S796
H07 on panasonic
hey I just messed around with mine it was showing that code H07 like the others its kinds the same except it holds 4 more disc, I took the top off then I took the thing that holds cd still off!, there should be a brass thing I think thats for the ground, so I ended up putting some synthetic oil on the rails silver poles that the laser slides on, and where the disc sits on that black circle under it, you can see the motor it has a white thing on the motores pole so I just put a few drops on there then spinds it put some more on hoping it works its way DOWN INTO THE MOTOR thats the H07 not spining fast enough!! I put a disk in while everything was apart and its playing right now, the oil I desided to use was the stuff I use for my paintball gun lol! its really thin and slippory and im sure it will last for awhile!.... going to add more after 15 minutes of playing just to make sure its really lubed! hope this helps!!!!
Jan 10, 2008 | Panasonic DVD-CP67 Multi-disc DVD Player
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Dec 23, 2005 | Panasonic DVD-CV37 Multi-disc DVD Player
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
