Question about Toshiba Portege 3500 Tablet PC
SD card reader
I'm trying to read my olympus xD picture card through my Toshiba Portege and it can't seem to "Explore" it. any suggestions?
    Scholar:
  • 120 Answers
Oh, see your AutoPlay Settings in Control Panel. Set it so that when a new drive with mixed content is connected, it should display it in a folder. There are numerous options. Just set it as you like it. It should open it up everytime you insert.
Or go to My Computer (or Computer in Vista) and double-click the card.
Posted on Dec 10, 2008
Photos on verizon tablet were not stored on sd card, how do I get them on sd card
According to Verizon support:
"From the Device to a Removable SD Card This feature is not available on the Verizon Ellipsis 7 Tablet"
However, you can transfer photos from the tablet to a computer; and then you can transfer them to a removable SD card if you have an external USB SD card port reader or one that's PC integrated.
According to Verizon customer support:
From the Device to a Computer
  1. Connect the device to a computer using the supplied USB cable.
    1. If necessary, select and hold the status bar (at the top) then drag to the bottom.
    2. Select Connected as a camera / an installer.
    3. Select Media device (MTP).
  2. Launch Windows Explorer.
    linote.gif Using the computer keyboard, press Windows+E ( windows_key_logo.jpg+E) keys.
    linote.gif Alternatively, right-click Start then click Open Windows Explore.
  3. Using Windows Explorer, navigate: QMV7A.
    linote.gif If you have a microSD card, you may transfer files to that location by navigating: QMV7A > SD Card.
  4. Utilize the computer to copy video/picture files from the following folders to the preferred folder(s) on the computer:
    • DCIM/Camera
  5. Disconnect the USB cable from the computer.
Feb 28, 2015 | Verizon Ellipsis 7 Tablet for Wireless
Hi, 1. How to transfer/copy bootable XP files onto SD card and then boot up Toshiba Portege M205 from the SD card? 2. Is it possible to made an image of my Windows XP CD on SD card? Regards Tad
Requirements
  • PC running Windows XP/2000 with a CD/DVD burner.
  • USB Flashdrive (Or some way to transfer files to the 3epc once Windows is installed)
  • SD Card, a fast SDHC is recommended of at least 2GB.
  • XP3eSD Utility
  • Hitachi Microdrive Filter Drivers
  • Partedmagic (or another bootable CD with disk cloning software)
  • Windows XP CD (SP2 Only Tested, may work with others)
  • Asus Eee PC (Of course!!)
Instructions:
  1. Copy all files from your XP Install CD to a folder on your Hard Drive
  2. Download the XP3eSD utility and run it to create a new install CD capable of installing Windows to boot off the SD card reader
  3. Boot your 3epc from the CD made in step 2
  4. Install Windows onto a FAT partition, deleting all the existing partitions
  5. When windows boots for the first time turn off the swap file, system restore, and the screensaver.
  6. Then stick your USB thumb drive into the EEE with the Hitachi Microdrive Filter.
  7. Next copy the files from your thumb drive to the desktop and then properly remove the thumb drive.
  8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the EEE.
  9. You need to then Hit Start go to run, and type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USBSTOR\
    Inside that you should find a directory called something like Disk&Ven_USB2.0&Prod_CardReader_SD0&Rev_0100. Open it. Inside that you should find another directory wich is just a bunch of numbers. Open it. In the right pane you should see a key called "Hardware ID" Right click on it, and select modify. It should list about 7 lines of text. Copy ONLY the first line to the clipboard. Hit cancel, close regedit.
  10. Open cfadisk.inf in the directory you unzipped the microdrive filter to. Edit the section called [cfadisk_device] so that rather than containing 11 lines, just have one line. The line begins with: %MicroDrive_devdesc% = cfadisk_install,
    After the comma, hit ctrl V to paste what you coppied from the registry into the file then save the file.
  11. Go to Device manager. Under disk drives, you should see SiliconMotion and USB2.0 Card Reader. Right click on the card reader and click update driver. Direct the driver updater window to the Hitachi driver you just edited. It won't detect the driver automatically, you have to specifty that your supplying the disk for the hardware and force it to use the driver.
  12. Reboot using the Partedmagic CD or USB Flashdrive, Download it here
  13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your 3epc
  14. Use 'fdisk -l' to find out the partition names of your SSD and SD.
  15. Type this command into a prompt: 'dd if=/dev/sda1 of=/dev/sdb1' When it finishes (it will take some time) type this command: 'dd if=/dev/sda of=/dev/sdb bs=512 count=1' (Note: If fdisk reported your SSD and SD as different than sda and sdb respectively, you must change that in the dd commands, if unsure ask in the support forums)
  16. When it finishes the task is complete, reboot and select to boot from the card reader
  17. Re-image the SSD of your 3epc with your restore DVD or USB.
Jan 27, 2011 | Toshiba Portege M205-S810 Tablet PC
WHERE IS THE SLOT TO UPLOAD MY 512mb SIMCARD ON MY TOSHIBA LAPTOP
take a closer look left or right side of ur laptop u may find it there
Oct 25, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
How do i load pictures from a sd card into computer
determine if your computer has a memory card slot for sd cards..
if memory card slot is not available use a "card reader" you can get that from walmart and on other stores
once memory card is connected.. it will appear on your
computer as a removable disk or device.. you can check that on "my computer" window for XP or "computer" window for vista..
you can explore the content of the memory card and get your files.. good luck!!
Sep 24, 2009 | Gateway CX200S Tablet PC
Usb cd rom will not boot can i boot from sd card
yes you must change the boot order and activate the legacy USB support if exsisted
Jan 25, 2009 | Toshiba Portege R100 Tablet PC
After a hard drive falure I need to install windows xp
At this moment I have taken the HDD out of the case, bought an adapter for its 1.8" interfce and proceeded over the USB. I was, however, installing Linux, with practically no experience with Windows.
Oct 21, 2008 | Toshiba Portege R100 Tablet PC
I cant use the USB port it always says " do you want to format it now"
Try go into devive manager and unstalling the port and restalling it there that might do it
Jul 28, 2008 | Toshiba Portege 3500 Tablet PC
Toshiba Portege 3500 Tablet PC Logo
199 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
