Question about HP Color LaserJet 2600n Printer
A very thin light blue line appears on all printing jobs
The line runs the length of the paper, about 2 inches from the right side.
Opening the door reveals a thin line on the transfer belt. The line is most likely toner as it can be removed with very light wiping. When wiping it with a bit of white paper, the color is hard to discern, but seems to have some blue and maybe red in it.
When I wipe it all off both sides of the belt, the line on the printed paper and the belt recurs.
If it's a toner leak, I can't seem to find where.
  • Anonymous Dec 16, 2008
    I have the same problem  but it's a green line on the left side of the page
  • davenval Dec 17, 2008
    When opening the door, I have one blue line on the right side of the film and a cyan line on the left side of the transfer film. There are also spots of red scattered in the middle. Definately toner as they are easily removed by wiping, but recur immediately. Wondering if it is a humidity problem?????
When vertical streaks or bands appear on the page, it means that one or more print cartridges might be low.
Posted on Dec 16, 2008
    Problem Solver:
  • 5 Answers
Have you tried running some printer cleaning sheets through it? They are available through Office Depot, Fry's and other stores.
Also, it could be an issue with the imaging drum. I've worked on several printers which have had a similar issue and they needed the imaging drum replaced. Typically that helped.
Posted on Dec 14, 2008
GET BLINKING GREEN LIGHT TO STOP AND PAPER TO FEED?
The green light should be blinking it is an indicator of power to the terminal.
if you have a printing problem let's first check how you are loading the paper. if you scratch the paper with your fingernail you should get a faint black line. the side of the paper that has the line should be placed in the palm of your hand. (facing down) if you take your hand to the opening of the terminal. and let the paper roll off your fingers into the terminal the side with the line should be down and you should be able to grab the beginning of the paper and pull about 2 inches past the opening of the paper load tray. then close the lid. making sure the roller on the lid is lightly touching the paper. do not feed the paper through anything it sits in paper load tray. there should be 1 roller- black in color that is the length of the paper and it should have a sprog (spindle) type wheel that has grooves that will push or pull another sprog to move the paper.
if you don't have one sprog and roller on the door you need to get a replacement door.
if you do have those close the door and press the 2nd purple key to your right. this is a reprint button, see if something prints.
if it is still not printing. make sure the paper is the correct size.
Feb 18, 2015 | VeriFone VX570 Credit Card Terminal (Dual...
My printer has started printing a black line down the edge of the paper?
Remove the laser print cartridge, shake it lightly, and place it back into your printer. That should solve the problem.
Mar 15, 2013 | Kyocera FS-1030D Laser Printer
We tried printing and copying with the setting set at LTR and LTR-R and we checked the paper tray and every time we make a copy or print it prints out the entire document perfectly centered across the...
It seems to me to be a problem of the Blue paper cassette size dial is set wrong. First see what the settings are from the display by pressing the paper select button. Most people have it set for the upper cassette to be LTR ( 8 1/2 X 11 inch paper - length running from front to rear in the cassette ) and the lower cassette to be LTR-R ( 8 1/2 X 11 inch ) or Legal ( paper length running left to right). Check to make sure the blue dial agrees with what's in the cassette. Try doing the testing by putting the paper on the glass first and closing the top. If this is correct and the problem is in the Documnet feeder then one of the raised flags may be broken or the sensor bad. The left one is for letter, the second one for LTR-R or legal and the third is for 11 X 17. The opening and closing fo the side guides also helps to determine paper size. Hope this helps you.
Nov 30, 2010 | Canon imageRUNNER 2270 Copier
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Streaks on printed page full length even after installing new cartridge
Check the glass (the one the paper rests on). The underside of the glass that is. This is what the light 'sees', so, it will print this!
Jun 03, 2009 | Konica Minolta PagePro 1350W Laser Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
Thin black lines (mp 530)
Here's the link for how to clean the unit... I was going to post the instructions here, but there are pictures that might be helpful to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Before doing anything more drastic, I would try this.. let us know how it turns out.. if it doesn't work, we'll go from there.
Maggie B
Feb 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP Color LaserJet 2600n Printer Logo
950 people viewed this question
Ben Johnson
