Question about HP Computers & Internet
The graphic card is install but no picture on the monitor when it is turn on
  • shadowsea18 Dec 10, 2008
    Yes it does have on board graphic, but how do you turn the on board graphic off in the BIOS? And how do you access BIOS? Is it the setup when you press the F1 button when you turn on the computer?
  • Thomas F. Schneider May 11, 2010
    Does the computer have on board graphics also? If so have you gone into the BIOS and turned off the "On board" graphics?
  • 2,692 Answers
Yes, That could be the setup for the BIOS.They all use different keys to enter BIOS /setup. Just look around until you find it, the onboard graphics disconnect.
Posted on Dec 10, 2008
  • 199 Answers
U must first set it ont the bios or reset the bios config, then pluge your external graphic card
Why when turn on computer there is a sound signal from computer but the monitor has no picture but monitor is okey.
If the monitor works on a different PC, the problem may be your video graphics card. If it is a builtin graphics card, you can install a graphics card and disable the integrated one if there is an open slot on the motherboard.
Aug 23, 2014 | HP pavillion media center m8330f pc
No picture in my monitor but the monitor is on
If monitor is on it could be (1. the screen cable is faulty .(2 then screen cable is not plugged in, or you have installed a graphics card and connected it to the on board and not the graphics card.If its connected to the motherboard or the graphics card and is not coming on then your graphics card or onboard is shot.If onboard is shot buy a graphics card and install it or replace graphics card.
Jan 04, 2014 | LG L192WS-BN Monitor
Trying to install ATI FireMV 2400 256mb pci-e card. I have a new pc with asus m4a78lt-m motherboard, athlon x4 645 3.1ghz processor, 3gb ram, windows 7 32 bit os, 500w psu Card installed in pcie x1...
First off all reset the bios to default setting and restart the system. After restarting the system please go to your bios in the graphics segment and select auto option for card selection.
once done save all setting connect your monitor cable to your monitor and restart the system.
hope this will solve your problem.
Apr 14, 2011 | ATI FireMV 2400 PCI Video Card
White vertical lines on screen. Unable to see pictures
check your graphics card connection to the motherboard when turned off. Try to install new drivers for the correct card. All else failts try a different monitor with same graphics card. If that doesn't work you know it's your graphics card. If it works fine, somethings up with the monitor itself.
Oct 20, 2009 | Apple iMac G4 Desktop
Graphic card problem
I think ur graphic card is not compatible with ur notebook.
u should reinstall old graphic card and reboot ur notebook.
if u want to install something new h/w in ur notebook then go to manufacturer website and check which h/w version compatible with ur notebook. Then try to install it in ur notebook.
Sep 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
The monitor turns white immediately after being turned on for about two seconds; and then immediately turns off leaving an un-powered screen. Repeating this process to gain access the control buttons does...
the problem is most likely you graphics card, if you have installed more than one graphics card you will most likely not get any picture from this.
remove any newly installed graphics card until you have installed the drivers for the latest one.
Aug 11, 2009 | BenQ FP71G 17" LCD Monitor
Hi i have just bought a new radeon x1650 pro 512mb graphics card and ive removed the drivers from my last graphics card and placed the new radeon into my computer. but when i turn it all on to install the...
When the card is properly installed and the system properly configured, you should at least be getting the POST screen, since that is not driver dependent. And Windows knows to go to the default standard VGA driver when it can't find specific drivers for a card. So we're looking at a hardware issue, not software.
Here are the troubleshooting steps I would take. Some would seem obvious and you've probably already tried them, but I like to be complete:
Is the monitor switchable betwwen two inputs? Do you have it set to the correct input (i.e. VGA vs DVI)? hit the selection button on the front panel, just in case.
Is the card properly seated? Take it out and put it back in. Also, oddly enough, reseating RAM can fix a lot of problems, even seemingly unrelated ones.
Is there an on-board VGA connector? If so, switch over to that and see if you get picture. Then go into CMOS settings and look for a video setting that would make the add-in card the default display. Or simply disable the on-board VGA.
Check the pins on your monitor connection, make sure none are bent.
If none of these get you a picture, I would suggest a defective graphics card.
Jul 22, 2009 | ATI RADEON X1650 Graphic Card
I installed the ATI x1650 but the monitor is blank when I turn on
Yes the card does support the screen. If you have blank screen right from turn on, chack that you have not plugged the monitor into the onboard graphics port instead of your Radeon. If you have plugged it into the right port then you have hardware problems. Could be any of the following:
1. Monitior
2. Video Card
3. System memory
4. Motherboard
5. Powersupply
6. CPU
Try a different monitor and get back to me if you want troubleshooting tips.
May 09, 2009 | ATI RADEON X1650 Graphic Card
No picture in windows after I install Graphics Card Driver
did you insert the G-card good in the pci-e slot(is the card new? can be it is wrecked,normally it runs witout installing the drivers but only in VGA mode,thats all i can tell u,exept you unplugged a cable on the motherboard for the pci alimentation?
by xenon
Mar 31, 2009 | Leadtek WinFast PX8600 GT TDH 512MB...
IAN ????????
I only work with a AGP 4X graphics card.
If you want to sell that motherboard im intressted. Mess me please
Jul 04, 2008 | Soltek SL-85DRC Motherboard
Computers & Internet Logo
67 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
