Question about Lexmark Wheelwriter 3500 Typewriter
The wheelwriter 3500, don´t write, only (_ 121), what´s that? what can i do?
  • 328 Answers
You may have the wrong keyboard selected. Try holding down the code key while pressing the L(lang) key.Release the L key and continue holding down the code key while you type the keyboard code number. USA keyboard is 001.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 02, 2007
SOURCE:
Lexmark wheelwriter 3500 indicates code 215.
215 is print wheel error. Remove the printwheel look for dirt and debris in that area, if you have a compressed air source blow thw P/W area out. If these don't work the printwheel sensor is likely bad.
DickyO
Jun 17, 2011 | Lexmark Wheelwriter 3500 Typewriter
2 line space lights blinking will not do anything
First you don't have a 3500 as it has no lights to blink if it is a WW1000 there is a very good chance your key board is bad. You can try my tip under WW1000 or contact Geo. Byters Co. for a KB rebuild
800-392-8085, tell them O'Reilly sent you.
DickyO
Jun 02, 2011 | Lexmark Wheelwriter 3500 Typewriter
I have an IBM Wheelwriter 3500 by Lexmark. The icon in the window shows a box with an upper left to lower right slash with the number 121. It turns on, beeps and will not allow anything to work. Help!
Error Code 121 means the keyboard is not recognized, check the connectors from the keyboard to be sure they are plugged in properly.
Try this turn it off remove the batteries, wait 30 sec. turn on all settings will go to default, memory will be cleared for any fault code stored.
Tell us news.
Aug 26, 2010 | Office Equipment & Supplies
Error code 121 what is it
i21 is an unsupported keyboard, which probably means the keyboard is bad. Contact Geo. Beters Co. for a keyboard rebuild
@ 800-392-8085 tell them O'Reilly sent you.
DickyO
Feb 11, 2010 | IBM Wheelwriter 30 Typewriter
IBM WheelWriter 30 Series II
The 121 indicates a keyboard problem, See my tip under ww1000 also check the two flat connectors from the KB to the PC mboard.
DickyO
Jan 15, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3500.
Does the display show aP/W nomber other than 001?
If it does hold the code key,press and release the "L" key type 001 release the "L" key this sets the keyboard to U.S., if this works the cure is to replace the keyboard.
DickyO
Dec 19, 2008 | IBM Wheelwriter 30 Typewriter
Error 121
121 says that the keyboard is not supported which means that the K.B. is bad. To get around this hold the code key, press & relase the "L" key type 001 rel the code key this sets the T/W to a US keyboard. You will have to do this until you replace the keyboard or repair it see my tip under WW1000.
DickyO
Jun 27, 2008 | IBM Wheelwriter 30 Typewriter
Code 120
Tou can try pressing and holding the code key, press and hold the "L" key, release code type 001, release "L" key. Your keyboard may be bad this will select USA keyboard.
Good luck
DickyO
Mar 28, 2008 | Lexmark Wheelwriter 3500 Typewriter
Wheelwriter 3500
Press and hold thr code while hitting the RELOC key on the rt. side of the keyboard the lower rt. hand corner of the display will change to indicate spacing.
Nov 05, 2007 | IBM Wheelwriter 30 Typewriter
Wheelwriter 3500 error code
This is memory cleared. Change the batteries, be sure to clean the battery contacts especally if they were corroded.
Dicky O
Oct 25, 2007 | Lexmark Wheelwriter 3500 Typewriter
Lexmark Wheelwriter 3500 Typewriter Logo
142 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
