Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Dishwasher # KUDS01FLWH5 NO LIGHTS AT ALL
I REPLACED THE WHOLE CONTROL BOARD AND STILL NO POWER OR LIGHTS, I HAVE CHECKED THE POWER AT THE BOTTOM AND IT IS LIVE, IS THERE MORE I SHOULD TRY OR JUST GET A NEW ONE IT WAS WORKING FINE AND THEN JUST STOPPED WORKING THE NEXT TIME I WENT TO USE IT. IS THERE A FUSE OR RESET SOMEWHERE! HELP
  • 2 more comments
  • wbradsh Dec 09, 2008
    WHERE IS THE FUSE ATTACHED TO THE CONTROL PANEL AT
  • wbradsh Dec 10, 2008
    wHERE IS THE FUSE ON THE CONTROL PANEL LOCATED
    AND DOES THE FUSE LOOK LIKE A REG FUSE OR WHAT BECAUSE I DON'T SEE ANYTHING THAT LOOKS LIKE A FUSE OR A RESET
    I TRIED HOLDING THE POWER BUTTON FOR 5-10 SECS DOES NOTHING, WHERE IS THE FUSE LOCATED AND WHAT DOES IT LOOK LIKE
  • KitchenAid Master
  • 19,396 Answers
Check this:
PS774514
FUSE-KIT
Is part nr.6 in this diagram.
If you do it yourself , work always with appliance power unplugged and with water drained, Ensure you replaced the part correctly and follow safety rules all repairs should be done by a qualified technician.
You can buy the part here: PS774514
Let me know how it goes.
Thanks
Posted on Dec 10, 2008
    Genius:
  • 1,199 Answers
Try holdind in power botton for 5 seconds this may reset it!
Posted on Dec 09, 2008
    Sergeant:
    Champion:
  • 291 Answers
There is a fuse attached to the control board and if it is blown it will not operate and 1st i would check the power under the dishwasher to where it connects to make sure you have a good connection and fire .... hope that help cause it has to be one of those to cause it to be dead / larryyb
  • 1 more comment
  • Larry Youngblood
    Larry Youngblood Dec 09, 2008
    it should be hooked onto it with 2 wires connected to it ,,,, you should have took it off when changing the board
  • Larry Youngblood
    it's part number 8193762 / larryyb
  • Larry Youngblood
    Larry Youngblood Dec 10, 2008
    it look like a small square stuck onto the control panel with 2 wires connected to it
Why does the top drawer have no power?
You also need to repair the solder link (over-temperature fuse) in the heater plate (or replace the whole heater plate). The drawer control board gets its power via that link.
Jul 20, 2015 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kitchenaide dishwasher KUDS25SHBS1
I have listed COMMON problems / reasons why a dishwasher won't start..
The thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Dec 15, 2013 | KitchenAid Dishwashers
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
My dishwasher seems to not be getting any power and no lights are lighting up. It is still plugged in and I already tried resetting breaker. Any suggestions?
HI. Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
If everything checks out ok with the above suggestion, the main control sector(timer or control board), will be the culprit.
The control sector must be replaced, in this case.
Dec 11, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher acts like it isn't getting power.
If you have power to the board and no power out to components then your board has failed. Will need to replace board. Part#154635501 and sugg retail is about$100.
Jun 09, 2009 | Dishwashers
Dishwasher stopped and will not start
Try jigling the ribbon cable that is connected to the control panel. These ribbon cables sometimes fail. Also check the fuse on the control board to see if it is blown.
Jan 02, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Dishwasher won't start - non responsive
Check the door switches. Both. and the wiring going to them
Jan 23, 2008 | Whirlpool DUL300 XTL Built-in Dishwasher
Whirlpool dishwasher
fuse on control board.
Jan 11, 2008 | Dishwashers
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
74 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
