Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
No ip address for router, unable to reset router or log into router to reset..
  • Anonymous Dec 26, 2008
    Router does not assign a valid IP.
  • 341 Answers
(username / password: admin / admin)
Posted on Dec 10, 2008
How can I find router I P address & password
Well it depends what ip address you are looking for - if you are looking for the local ip address all you have to do go is go to the command line and type in "ipconfig" without the quotes. What you are looking for is the gateway address.
If you are looking for the ip address the rest of the world sees it will be a little more tricky. The first thing you are going to want to do is log in to your router. You can do this by opening your web browser and in the address bar typing the local ip address of you router. (It should be
You will be prompted with a log in box. The default username is admin and the default password is password. If you cannot log in using these credentials and do not remember if you have changed the password all you have to do is get a small pointy object (pen, paperclip, pin etc). Look on the back of your router for a small hole that says reset on it and push it in for 30 seconds. This will reset it to factory default settings - if you are wirelessly connected to your router you will have to reconnect to the network it will be called netgear most likely. You can then log in to your router.
Once logged into your router click on the "Maintenance" heading on the main screen then select "System Status"
Your IP address will be listed under the "Internet Port" heading.
Feb 23, 2011 | NetGear WGR614 Wireless Router
Router will not connect
Depending on what router or connection you are using try these steps.
Windows XP
1.Powercycle all equipment (Unplug)
2.Wait 15 seconds and plug back in.
3.Go to Start/Run/Type ncpa.cpl
4.Double click the connection you want to connect to
5.Click on tab next to General
6.Ensure that it is assigned by DHCP
7.Ensure It has a valid ip address It should start with 192.
8.Go to Command Prompt Start/Run/Type CMD and hit ok
9.Next to C: Type netsh int ip reset reset.log
netsh int ip delete arpcache
netsh winsock reset
ipconfig /flushdns
10. Restart Computer
1.Start/Search Bar/Type ncpa.cpl
2.Right click on the Connection you want to connect to
and hit Properties
3.Uncheck Internet Protocol Version 6
4.Click on Internet Protocol Version 4 and hit Properties.
5.Ensure Obtain an IP address automatically is checked
Ensure Obtain a Dns Server automatically is checked as well
6.Exit out of everything
7.Go to Start/All programs/Accessories/Right click on Command Prompt and hit Run as Administrator then click continue.
8. Type: netsh int ip reset reset.log
Type: netsh int ip delete arpcache
Type: netsh winsock reset
Type: ipconfig /flushdns
9. Restart your computer.
10. If you are still unable to access the internet you may have a virus I would suggest running an Antivirus. I hope this Helped Good Luck
Oct 02, 2010 | Belkin Computers & Internet
I have Dlink 615 model router. i reset one time and now i want to change again my name and password but i cant log into. I try admin in with the IP address and also my user name and password but i cant get...
When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
default IP: (make sure that your network cards IP address is somthing similar like and not
Default username: admin
Default pass: leave blank
If you are still having issues let me know.
Jun 20, 2010 | D-Link DIR-625 (790069292637) Wireless...
I want to log in to my routers ip address
Connect your router to computer with ethernet lan cable.
Then you can access with below link
type user as "admin" and password as "admin" or blank or "password"
If you are unable to login with above ip then you need to reset router.
For that press RESET button for 10 seconds it is in back side of router.Hold it for 10 seconds thenj all settings defaults.
Then try with above ip .
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 22, 2009 | NetGear WGR614 Wireless Router
Cant access to my D-link wireless access point to creat a wep key..what i wana do?
1. Do not attempt to configure your wireless router with a wireless connection. If the wireless connection gets interrupted, you may (probably will) not be able to reconnect to the router.
2. Go to
3. Download and install pingplotter. The free version.
4. Run ping plotter to determine the IP address of your router. Click on and click on trace. Your router will be the FIRST IP address listed.
5. Write the IP address down. If it is not someone has already configured the router.
6. Log in to your router using a wired connection with the IP address you wrote down. (if you cannot do this due to fthe router being pre-configured by your Internet Provider or other problems, you can force your router to reset to the factory defaults and configure it yourself.
6a. Use a straightened paper clip or similar object to force the router to reset itself to the factory defaults. Put the paper clip in the reset hole next to the WAN connector on the router and hold it for 10 seconds. This will force reset your router.
7. Remove the power from your router for at least five minutes. This will cause your IP to reset his connection to your router.
8. Log back in to your router using a wired connection.
9. The default D-link IP address is The D-link default user name is admin. The password is blank. No NOT blank, just enter nothing but the user name and click on the next button.
10. You should be able to configure the router to your satisfaction.
11. Remember to change the Administrator log on information (name and password).
12. You may find it necessary to duplicate a MAC address in order to connect to your IP.
Nov 24, 2009 | D-Link : DWL-2100AP Wireless-G 108Mbps...
Can't get it configured
Try to reset the router using a paper clip, then try to re-log in to the router with the IP address, If you are still unable to log in , try log as admin as the username and password as admin or admin on the username and password is password.
May 26, 2009 | Buffalo Technology AirStation G54...
2wire IP page won't log in??
If the above doesn't work, try resetting the router back to its factory defaults.  There should be a reset on the router.  Then try the address or
Apr 24, 2009 | 2wire 1800HG Router (RG1800HG00)
Unable to connect to internet
The IP address you use with your browser is not to get into the Dlink WEB page, it is to get into the DLink router configuration, to set up the router and wireless security eg. network SSID, turn off SSID brocast, WEP/WAP encryption, MAC address filtering etc.
Apr 19, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Cannot log on to dwl2000ap
If the SSID changed to the default then you know that the router reset to the default settings and you should set your computer to automatically get its IP address via DHCP. I always set up my routers through a Wired connection first, just to setup the router and then go with the wireless. The default for the router should be and subnet . If the computer is set with a static IP address, change it to obtain an IP address automatically or the network card will not bother even looking for an address.
Aug 17, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Router unable to acquire ip address
You're not telling us much. What's the OS and what have you tried? Wired or wireless? This problem is usually solved by resetting the router to defaults and starting over, following the directions carefully.
Oct 07, 2007 | D-Link (DI-784) Wireless Router
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
182 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
