Question about OKI C5100n Laser Printer
Oki 5500 n
Does anyone know how to reset the drums and fuser on
the oki 5500n. Mabie using the admin code??
You cant do it via admin code or software.
Inside every part is a little green picofuse.
When the printer starts, it looks for continuity. If present, it burns the fuse and resets the corresponding counter.
If you want to be creative, you can replace the little fuse. Easiest done in belt and fuser. Almost impossible in drums.
Or one might construct a little device with a fake fuse to insert between the part and the corresponding connector.
Posted on Dec 17, 2008
Hp COLOR laserjet 5500
Power off the device. Remove the new fuser. Ensure there is no debris or paper through the paper path (blow some air through it.. Ensure all the flags are neither broken nor in the wrong position. Reinsert the new fuser, ensure the covers are properly in place then power on.
Jul 09, 2014 | HewlettPackard HP Color LaserJet 5500n...
What part number do I need to replace the fuser E on a OKI B6300N? Is this the same thing as a drum?
The drum is not the same as the fuser unit. The fuser is sold as part of the maintenance kit. I've found two part numbers: one for a printer that uses 110 V: OKI-50230120, and one for 220V printers: OKI-50230130.
The drum holds the toner from the toner cartridge; the fuser heats up and locks the toner to the paper. http://www.fastprinters.com/oki-supplies.asp is one source that seems to still have these in stock for both power configurations. However, I found several links for the 110V version with Google. (Some have it in stock; others don't).
I hope this helps.
Sep 08, 2010 | OKI B6300n Printer
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
May 19, 2010 | OKI B6500 Led Printer
Oki c5500n drum reset
You must buy a chip to reset the 5500n
You can get them along with easy to refill toner from
several sorces.
Apr 21, 2010 | OKI C5500n Printer
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
Xerox 5500 jaming at tray 3 and 2 constantly
There are mylar guide strips that get bent if paper is misloaded and the drawer is shut. Otherwise you need new paper feed rollers, which are part of the fuser maintenance kit.
Sep 28, 2009 | Xerox Phaser 5500N Laser Printer
Oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Jun 19, 2009 | OKI B4600 Printer
OKI5500 color drums reset
No, when you need to replace the drum, you must replace the drum. You don't want to mess around resetting fuses on the drums. They go about 10,000 pages on the 5500; then start to make lines, streaks etc on the printout. Why would you want that.
OKI Certified Technician.
Jason
Mar 10, 2009 | OKI C5500n Laser Printer
Fuser reset / transfer reset
RESET OKIDATA TONER DRUM by RTINSC (11/17/05 10:34 AM) reply + / -
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Aug 11, 2008 | OKI C5510 MFP All-In-One Led Printer
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
OKI C5100n Laser Printer Logo
452 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
