Question about Acer Aspire 3680 Laptop
Laptop stoped i have a aspire 3680 2574 and it stoped working. the battery is good. i try the ac adapter "which works" and then try to turn it on and the ac adapter light just flashes a couple of times and then it stops.
  • nas john
    nas john May 11, 2010
    please try to get another AC adapter and try it out. try to swap each part of your adapter right from the power source to identified which part is fault. this will help you to minimize costs of repairing.
  • 70 Answers
There is a short circuit in the laptop inside.
Posted on Aug 23, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Acer aspire notebook will not switch on after battery discharge even with mains adaptor plugged in. Help Noel
1. Remove the battery and the ac adapter from the laptop computer. Press the power button for about 10 seconds. This will discharge thee flea power from the laptop.
2. Connect the battery and the ac adapter. Charge the computer for about 30 mins then try to turn the computer on.
If this does not work, try to turn the computer on with only the AC adapter connected. If this works then it time to replace the battery.
Jun 26, 2011 | Acer Aspire One PC Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
It just wont turn on i have checked the power lead and its ok its an acer aspire 5050 laptop
Hi. I would suggest you double check the ac adapter if the powercord is properly attach to it ot also you might want to try powerdraining or powercycling your computer. To do this you must turn off your laptop then remove the battery and unplug the ac adapter then press and hold the power button for 20 seconds while the battery and ac adapter is out, after that place back the battery and plugin the ac adapter and try turning on your laptop, if this doesnt work then try power draining it again and just use the ac adapter or just plug it in without the battery then try again turning it on. If it still has the power issue then try a known good ac adapter so that you could double check that it is not an ac adapter issue or a battery issue. If all that trouble shooting step doesnt work then you could also try calling acer tech support to help you on your issue if your machine or laptop is still under warranty they would help you fix it by sending that laptop to there depot without any charge. Hope this Helps
Jun 09, 2010 | Acer Aspire 5050-3242 Notebook
Acer aspire 5520 laptop. Is it dead?
To verify it isn't a battery issue you can try taking the battery out completely and plugging in the A/C adapter and turning it on.
Without more information it's hard it's hard to diagnose your issue more specificially. Do you get any lights on the front?
Jun 21, 2009 | Acer Aspire 5520-5579 Notebook
No power. Adapter light flashes when connected to laptop
thanks for using fixya!!
Please do and observe the following:
1. Uninstall the battery pack.
2. Then, connect the AC adapter, we will try to use the power coming from the AC, then turn on your laptop.
3. Observe what will happen.
4. If still doesn't work, install again the battery, then connect the AC adapter, check if its going to work.
5. If not, perhaps you have a problem neither with the battery or the AC adapter.
I suggest that you bring your laptop to a service center. Good luck!
pls rate me positively! thanks!
Mar 30, 2009 | Acer Aspire 3680 Laptop
Computer stoped working
If you're certain that the battery is fully charged, then there could be an issue with your hard drive, or possibly motherboard.
Has the laptop ever been wet, or outdoors overnight?
See if you can boot from your disk drive by inserting your operating system disk in the drive when you turn it on.
Also double check that the outlet you're using is actually supplying power, I have bad outlets in some parts of my house where my laptop won't charge up.
Hope that helps, keep me posted
Dec 11, 2008 | Acer Aspire 3680 Laptop
Laptop stoped working
I have an Aspre 3680 as well, and a flashing adapter light is not a good sign, I suggest you get a multi meter and test for to make sure you are getting the 19 volts output that are required to run the laptop and charge the battery.
My goal is to provide you with a helpful fix ya solution, if you found this advice helpful please rate it as Fixya, thanks
Ken
Dec 09, 2008 | Acer Aspire 3680 Laptop
Turn on/off
remove battery try another wall outlet check ac adapter is getting AC power check ac power jack on laptop is not loose. try another ac adapter
Sep 01, 2007 | Toshiba Satellite A10-S167 Notebook
Acer Aspire 3680 Laptop Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
