Question about Acer Aspire 3610 Notebook
Help me please we have an acer aspire 3610 a little while ago the screen started to act funny, getting dim or flickering. then soon started turning off and not coming on until rebooted, now it doesnt come on at all so i hooked an external monitor to it i get to the password screen enter it windows xp sign comes up and then is gone and the external monitor shuts off
  • tonylee000 Jan 03, 2009
    when windows boots it go into a different mode that your external monitor is incompatible with; or - more likley - you dont have external monitor activated in windows, if you can get the laptop monitor working briefly go into you monitor settings (right click on your desktop / properties, tab: settings and option Display) change to external. you may need to install.
    i have this problem with a 3610 that has the monitor removed do to ill health! lol
    reloaded windows but that uses the laptops own by delault, any ideas ne1
  • mellie3182 Jan 06, 2009
    At times when I would shut down my computer, the screen would go to a funny color and not shut down. I had to remove the battery to cut the computer off. Now, when I cut my computer on the screen stays black. Can anyone help me? I've called Acer Technical Department a couple of times but was put on hold for 1:30 to 2:00 hours.
  • 3 Answers
Sounds like your video card has a problem
Posted on Dec 10, 2008
Acer aspire 3610 screen flickering
It sounds like your video cable or your Lcd Inverter cables might be loose. You will need to take the lcd apart to get to them. The video cable is on the back of the LCD screen at the top. Remove it, then push it back in and use a piece of tape over where it connects to hold it in place. Also remove the other end of the video cable from it's connection and plug it back in. The lcd inverter is at the bottom under the lcd screen. It has two cables going into it. Remove both cables and then plug them back in. Put everything back together and hopefully your problem of flickering will be solved.
Mar 30, 2012 | Acer Aspire 3610 Notebook
Acer Aspire 3610
How far does it get in booting. Do you see the Windows screen with the side scrolling bar before it reboots. During the boot process, start hitting the F8 key once a second until it drops you into a menu where you can select to start in Windows with safe mode. If you cant get that far, hit the DEL key a few times a soon as you boot the computer to try to go into your BIOS. If you can get into either of these, I may be able to help you.
Jan 23, 2008 | Acer Aspire 3610 Notebook
How can i find out part numbers for acer aspire 3000/3610. I have a 3000 (broken screen) and a 3610 (dead) , can i swop the screen from my 3610 into my 3000?
The Acer 3000 series and 3610 series has different set of Parts, Hence Swapping the LCD screen may damage your other 3610 LCD also. Please try to get a replacement for Aspire 3000 LCD.
Thank you for using Fixya.
Oct 08, 2009 | Acer Aspire 3000 Notebook
Screen flickers, Ok when you "tap" side of unit. Something loose or bad connection.
Most LCD inverters are located behind the screen bezel at the bottom of the screen near the hinges.
May 18, 2009 | Acer Aspire 3610 15.4 Glossy WXGA LCD...
Screen flicker (only when ac power is removed)
Hi there
yes its the graphic drivers that needs installing, i must also tell you that when you remove AC power from the laptop it will go into power saving mode and you will notice that the screen dims a little, this is normal and nothing to worry about
Kind regards and please don't forget to rate us
Dec 12, 2008 | Acer Aspire 4315 Notebook
Screen black out
Was it going a pink colour on the bios screen and now if you look close enough at the screen can you see your desktop?
Cheers
Jun 15, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610
The problem is that the power inlet jack has a bad connection on the motherboard. The way to resolve this is to remove the motherboard from the laptop and resolder the jack. This is not a repair I would suggest for the novice. If this is not repaired soon, further damage can be done to the motherboard that may not be easily fixable. Please have this repaired soon.
Dan
May 29, 2008 | Acer Aspire 3610 Notebook
Screen flickers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3610 Notebook
Acer Aspire 3610 screen problem
when you first boot up do you get all the screen then windows starts and get part screen if so just reformate hard drive start all over if not then i think you have broken screen
Oct 20, 2007 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
