Question about Brother IntelliFax-4100e Fax
Printing all document out the back of machine
I can send and recieve documents just fine, however my confirmations and incoming faxes are all printing out the back in reverse order. I cant figure out how to make it print to the front tray again and I dont know what I did to begin with. Please help!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
There is a lever in the back, lift it will divert the papers to the front again. ( looks like a small door)
Posted on Dec 12, 2008
Cant send fax out. getting a message exceeded job memory. How do I clear this
Dear
As the model is not mentioned its difficult to right solution. But in general when a document sent from memory some times this happen. This is frequent if memory recieved is more and not printed.
Its cleared on printing all memory recieved or memory cleared(all received fax will deleted).
Also sending fax manually may be done.I.e.Dial the fax no.get the fax tone load the document press start or send. Also in setting the scanning resolution may be minimised up to150/200dpi for less memory.
Thanks.
Feb 04, 2015 | Office Equipment & Supplies
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
MY FAX MACHINE CAN NOT RECEIVE FAX FROM OTHER, THE DISPLAY IS FAX MEMORY FULL, HOW TO SOLVE?
This means that your fax is only storing into its internal memory and not printing all incoming faxes, therefore it has no more space for more incoming documents, you should print the documents and maybe you'll need to clear the memory, depending on fax machine, this is done automatically when the documents are printed, and of course, set the incoming faxes to print not to store, this feature is supposed to be used only when the fax has no paper to print.
Mar 15, 2011 | Computers & Internet
Multiple printing
go to the main menu and go to the printing settings.adjust it to single printing...
May 20, 2010 | Panasonic KX-FM131 Fax
Printing out a confirmation page for a document automatically
press FUNCTION, 7, 4, SET, 1, 2, SET, 2, SET, STOP...It will print everytime you fax out a document.
Oct 02, 2009 | Panasonic PanaFax UF-8000 Laser Fax
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Fax in receiving faxes but not printing them.
noavatar.png Incoming faxes automatically go into memory. We can't print them out. Would like incoming faxes to print out as they used to. have tried the on off button but it didn't fix the problem
Apr 16, 2009 | Canon FAX-JX200
Send Fax Issue
I have a brother intellifax 770 and I bought it used so their for I do not have the owners manual and I am having trouble setting it up and getting it to work. I can fax out but I just can't recieve faxes I can fax my daughter but when she faxes me she gets an error of 388 but she is able to fax and recieve faxes so we know her end is not the problem.
Aug 20, 2008 | Brother IntelliFAX 4100 Laser Fax
NOT PRINTING SENT FAX REPORT
Make sure your in fax setup your message confirm is ON and not on ON-ERR. The Sf-560 also has an issue with the phone jack on the back becoming loose and causing sataic. Needs to be resoldered
Mar 26, 2008 | Samsung SF-560 Plain Paper Laser Fax
Brother IntelliFax-4100e Fax Logo
122 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
