Zio Corporation  CD-RW Burner
Problem for Zio Corporation (DM-3000) CD-RW Burner
Discs burned on your drive can't be read by other drives?
By Perkins - usenet poster
Same Problem
Jan 24, 2008
-   I have a problem with my Dell 3000 burner. it will burn, but then you cannot get it to play, yet you put the cd in to burn something else and it says that to put in a clean disk. What do I do? Also, if I try to send a fairly big email file, the recipient cannot open it-   learner51
Jan 13, 2008
-   I can burn a CDG disc perfectly but when i use the CB9168 as an external drive and  try to burn CDG's from the computer, it only plays the audio. Where is the video?-   Guest
Best Solution
posted on Jan 11, 2006
Helpful)
Fafhrd
Rank: Master
Rating: 86%, 159 votes
fafhrd indicated that his solution for
(042DX) CD-RW Burner Problem
is valid for all Zio CD and DVD...
This is a semi-common problem among Dell Burners and the software for some reason. Out of the 40 Dell laptops we have 3 of them contained this problem. This problem is worse when burning audio CDs. If you have tried another CD media out then try some of these solutions to help you out:
1. Close your session. Make sure you are closing the CD/session if you are using the default program for Dell (Easy CD Creator) you can close your session by clicking on the "Record" button this will open up the Record CD Setup dialog box, inside the Record CD Setup dialog click on the button labeled "Options" and then under the section labeled "Record Method" click the option for "Finalize CD". Now try to burn that CD.
2. If you are using Dell's pre-installed default burning program (Easy CD Creator) you might want to upgrade the software. There have been reported errors and bugs that do not finalize some CDs in versions old then 5.3.4.21 SP8. To download the updates from Dell: Go to http://www.dell.com, click on "Home and Home Office", then click on Support then go Downloads, enter in your service code or select your model from the drop down box then click on GO. Next enter your Operating System and then click on "Find Downloads" link. Under the category "Patches and Fixes" select the Easy CD Creator update. Run the installation and follow the instructions.
3. If all else fails, flash your BIOS, to do this: Go to http://www.dell.com, click on "Home and Home Office", then click on Support then go Downloads, enter in your service code or select your model from the drop down box then click on GO. Next enter your Operating System and then click on "Find Downloads" link. Under the category "FlashBIOS Updates" and download the Harddrive installation version. If your BIOS is older then A6 you may want to upgrade it, Dell added a bunch of hardware support.
Was this helpful?
Yes
No
Solution #2
posted on Aug 08, 2005
Somewhat Helpful)
lawyer
Rank: Apprentice
Rating: 0%, 0 votes
1. Try a different brand of CD-R media. Some drives like a particular brand, while others refuse to give it the time of day.
2. Make sure you have your CD-writing software set to "close the session" or "finalize" on discs you're writing.
3. Dust can affect your CD-R lens. You can clean the interior of the drive by blowing compressed air into it (with no disc inserted). You can also buy a standard audio CD player cleaning kit (see How to Troubleshoot a CD Player).
Was this helpful?
Yes
No
Popular Solutions for Zio Corporation CD-RW Burner
Questions and Unsolved Problems for Zio Corporation CD-RW Burner
Do you recommend Zio Corporation (DM-3000) CD-RW Burner?
Answer
Answer
which type recover my pc drive it is loses in running computer
Answer
I have same pictures in a folder, which are already burned some weeks back in a writable CD.It... (More)
Answer
my cd's are not being read after i burn or copy them
Answer
my cd's are not being read after i make or copy them
Answer
my cd burner drawer will not open it is a memorex
Describe your CD and DVD Burners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burner Experts
Top Computer & Laptop Repairmen
in , GA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
