Question about Euro-Pro F1066 Deep Fryer
I have an Europro1065 and it stop working. Where is the reset button?
  • 1 more comment
  • neatoglesby Dec 09, 2008
    Yes. It stopped working. I took it apart cleaned the gunck from the bottom plugged it in and it still would not work.
  • neatoglesby Dec 10, 2008
    yes, but where is the reset??
    I still didn't get my answer, Where is the reset button on the Europro 1065????
I was a bit stupid after I washed the unit it didn't work. I noticed the reset button (in the back of the display where it screws together, I had a black plastic reset button). That was not my problem, when I put the element back in, I didn't notice the plastic rail that it slides in. Without putting it in the rail it doesn't offset the safety switch.
I hope that makes sense and will help.
Posted on Feb 21, 2009
  • mamaoftwi228 Sep 02, 2011
    Holy smokes this worked. I did the same thing and after cleaning it , i thought I ruined it. Tried the reset button and everything. When you mentioned the black rail on the end the control panel slides into I ran over there slide it in and TaDA it worked! Dont know why I never saw or thought of that. :) Thanks so much .,
Well, we had the same problem and I just got ti to work, someone posted the solution for one of the other models. The reset button is on the back of the element component (the one that you plug in to). Just as the other person said, it looks just like the screw hole, but it's a little black button (use a flashlight if it will help).
In my case pressing it directly didn't quite have that effect, it looked like it was in a permanently de-pressed state, so I decided to take it apart. Unfortunately, one of the screws is not a standard one, it has a triangle head, so i loosened all the others, wedged it open, and then pressed the button and wiggled it around from the inside (with a long flat instrument (like a table knife) for good measure I tapped on the little red button/dial looking thing that was just below it too.
I was skeptical that it would work, since the button never really popped back out like i was expecting, but in the end, i tightened all the phillips head screws back up, plugged the unit in, and voila - it works...
Hope this helps,
AG
Posted on Dec 23, 2008
    Genius:
  • 1,199 Answers
Make sure its put back together right! push reset!
Posted on Dec 10, 2008
Canon Pixma MP160 stopped working, showing E 2 - paper is not jammed - Printer is NOT hooked up to a computer - only used for scan and print in farm shop (heated) - suggestions? It is an oldie but a...
First thing to try is pressing the "Stop/Reset" button. If that doesn't work, hold it down for more than 10 seconds and release. If that doesn't work try turning off the printer, unplug the power cord for more than 10 seconds then reconnect and turn the printer on again.
If the printer was connected to a computer, there might be more information provided about the source of the problem. Otherwise, a last resort would be to reset the printer. Follow this exactly:
  1. Turn off the printer (using "Power" button) but leave it plugged into the wall socket.
  2. Press and hold the "Stop/Reset" button (red circle in the triangle), and without releasing the "Stop/Reset" button, press and hold the "Power" button (indicator light shows green).
  3. While holding down the "Power" button, release the "Stop/Reset" button.
  4. Continue holding down the "Power" button, double click the "Reset" button and release the "Power" button.
  5. Click the "Stop/Reset" button four times
  6. Press the "Power" button to confirm and turn the printer off. Turn printer on again.
Feb 18, 2015 | Canon PIXMA MP160 All-In-One InkJet...
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error 27
Turn off your printer and press the POWER BUTTON while pressing and holding the STOP/RESET BUTTON.
When the Power on, press the STOP/RESET BUTTON twice while pressing and holding the POWER BUTTON.
Release the POWER and STOP/RESET BUTTONS. Your printer will now move into the service mode.
When the power light turns green, press the STOP/RESET BUTTON 4 times.
You will then notice that each time the STOP/RESET BUTTON is pressed, the LED lights change from orange to green.
Now turn off your printer, then turn it back on.
If it doesn't work, keep trying from first step.
Oct 29, 2010 | Canon Office Equipment & Supplies
Ink cartridges replaced still saying it is empty
After replacing the cartridge do these steps:
1. Turn off the printer... (make sure the power plug is connected to the wall outlet)
2. Press and hold the Stop/Reset button
3. While holding the Stop/Reset button, press and hold Power button.
4. While holding the Power button, release the Stop/Reset button.
5. While still holding the Power button, press the Stop/Reset button twice.
6. Now release the Power button. (wait until it display "service mode")
7. Press the Stop/Reset button 8 times to reset the ink level.
8. Turn off the printer.
When you turn on the printer it will work now.
If error still persist, do these
1. Press and hold the Stop/Reset button and wait until the printer self-restart.
Much appreciated if you will give my solution a four thumbs up rating.
Thank you for using Fixya
Sep 14, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber full
error 27???
you can reset your printer..
1.with the printer powered off but connected to a power source,press the power button while pressing and holding the stop/reset button.
2.when the power is lit,press the stop/reset button two times while pressing and holding the power button.
3.when releasing the power button and stop/reset button(regardless of order),the printer will move into service mode.(wait for menu selection)
4.when the on/off light is green,press stop/reset button the specified number of time(s)according to the function listed in the table below..(each time the stop/reset button is pressed,the led lights alternately in orange and green,starting with orange.)
note:press 4 times for waste ink counter reset..
if did not work try more..
not work again you can change the sponge...
Jun 10, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My hp officejet 6210 has a message reading remove and check color cartridge? And I do what it says and it just repeats and repeats?? Whats wrong with it? Should I buy a new color cartridge?
Hi you can try this may work.
In service mode.
Put Stop/reset 4 times orange => reset waste ink.
Put stop/reset 8 times orange => set level ink.
And try this.
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
For me, it worked when I did this:
1) With the printer powered off but connected to a power source, press and hold the Stop/Reset button for 4-5 seconds.
2) Without letting go of the Stop/Reset button, press and hold the Power button. Then, press the Stop/Reset button two times without letting go of the Power button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | HP OfficeJet 6210 All-In-One InkJet...
How do you override the ink level gauge on a canon mp630? It has a stop button but no reset button.
In service mode.
And try this.
Feb 09, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Error 5800 on Canon Pixma MP170
Solution #1 worked with my MP170 but it could be described more clearly, as follows:-
1. If the power is on, turn it off (press the on/off button).
2. Hold down the stop/reset button (red triangle in red circle).
3. Whilst still holding down the stop/reset button, hold down the on/off button.
4. Whilst still holding down the on/off button, release the stop/reset button.
5. Now press the stop/reset button twice, quickly.
6. Next release the on/off button.
7. Wait untill the LCD display shows “Canon idle” (this may take a few minutes).
8. Now push the stop/reset button 4 times in succession, quickly.
9. Press the on/off button twice, quickly.
10. Now press the on/off button to switch the power off.
11. Finally, press the on/off button to switch the power back on.
This sets the ink pad counter to zero, even though the pad still contains ink.
Remove ink from the pad, as follows:-
Open the lid of the printer to reveal the cartridge track and ink pad.
Winkle out the ink pad, using a pin or a small screwdriver or tweezers.
Wash the ink pad in clean water, squashing the pad to remove the ink.
Dry the clean pad by squashing it between sheets of kitchen paper.
Replace the pad, taking care to fit it between the alignment notches.
Amen!
Jan 09, 2009 | Office Equipment & Supplies
Canon mp780 -waste ink near full??
Dear mr perfect,
Few days ago I have answered the same question about this for Canon MP700. Here is my answer:
Waste ink absorber capacity of your printer has rise to about 90-95 %. Tentatively, you can continue printing by pressing STOP/RESET button. When ink absorber capacity reach about 100%, the printer stop working and message 'Waste Ink Tank is Full' appears.
To fix this problem, you need to reset waste ink counter. It strongly recommended that you replace waste ink absorber after resetting waste ink counter.
Here are steps resetting waste ink counter of this printer:
  • With the machine power off, while pressing STOP/RESET button, press and hold the ON/OFF button. (Do not release the buttons).
  • While holding ON/OFF button, release the STOP/RESET button. (Do not release the ON/OFF button).
  • While holding the ON/OFF button, press the STOP/RESET 2 times and then release all buttons. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • When the COPY button lights in green, press STOP/RESET button 4 times. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • Turn off the printer.
Your printer should work normally now.
Regards,
Source:
Canon IJ Forum
Dec 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
I have a Canon MP700 Printer. The message "waste tank nearly full" appeared. As I couldn't find any help in the manual I removed the ink cartridges to look for a "waste tank". ...
Dear miggsy,
Regards,
Source:
Canon Inkjet Printer Forum
Dec 05, 2008 | Canon Office Equipment & Supplies
Euro-Pro F1066 Deep Fryer Logo
311 people viewed this question
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gerry Harvey
Gerry Harvey
Clarice Bornschein
Level 1 Expert
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
