Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
Emerson LCD picture problem
I have a 20 inch Emerson LCD tv model #EWL20S5C.  Something has happened to the picture.  The screen shows 2 of the same picture divided by a line down the middle.  The pictures are blurry and the people are not moving.  The sound is fine.  Any ideas what might be wrong and if it's worth the price to fix it?
  • 2 more comments
  • jayc30088 Dec 24, 2008
    I just noticed the same problem ... just started searching for a solution.
  • jmvlv111 Jan 07, 2009
  • Soulreaver69 Apr 20, 2009
  • sballgirl Apr 20, 2009
    My problem is exactly the same. The picture is split in the middle and the screen is white when you first turn it on. The sound is fine, but the screen is messed up. I just turned it on one day and it looked like that... help!
freetek
  • 5568 Answers
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
  • 16 Answers
SOURCE: Emerson EWL20S5C Shuts off after 10 secs
one of the inverter transformers has gone out this will cause the set to shut down as described in the problems stated above no need to replace the main module.
Posted on Oct 09, 2008
daniel719
  • 240 Answers
SOURCE: price
the power supply is bilt into the main pcb board, it needs to be repaired
comen failure in thees is the bridge diods a repair in any shop will cost from $40 to 60.
regars,
daniel.
Posted on Jan 13, 2009
  • 56 Answers
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Posted on Feb 02, 2009
dsacco86
  • 1077 Answers
SOURCE: Emerson LC320EM82 S LCD TV I purchased this TV a
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Posted on Jun 18, 2009
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Feb 13, 2015 | Emerson LD195EM8 19 in. LCD TV
Where can i get a manual to help me program a LCD EMERSON TV model EWL 20S5 TVwill not show picture if not connected to cable
<a href="http://tv.manualsonline.com/manuals/mfg/emerson/ewl20s5.html">http://tv.manualsonline.com/manuals/mfg/emerson/ewl20s5.html</a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Aug 25, 2010 | Emerson EWL2005 20 in. LCD Television
My Emerson EWL20S5C will not stay on. Has anyone figured out the cause yet?
Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light flashing codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 13, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Price
regars,
daniel.
Jan 13, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
2 year warranty
the Majority of problems on this and all other LCD TV's are capacitor problems the power pack needs smooth power to work correctly however the warranty should be valid and you need the proof that you bought it and you need to know who to contact about the 2 year warranty it may be Emerson you need to speak with not Walmart. I would contact them next(Emerson), or whom ever the third party repair service is that will cover the Warranty.
hope this helps
Nov 19, 2008 | Emerson EWL2005 20 in. LCD Television
http://www.hypercubetech.com/EWL20S5_shutting_off_problem/index.html
Jan 12, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
240 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
