Question about Canon P1-DHV Calculator
Loading printer paper
Cant find manuel to load paper in my calculator. can get paper in but will not feed through all the way.
  • 1 more comment
  • kirkdrums Dec 26, 2007
    Same problem here, no manual and it is a real pain. No obvious way to thread it. HELP!
  • Anonymous Jan 07, 2008
    same problem. Cannot remember how to load paper. Lost manual. Help!
  • Anonymous Feb 21, 2008
    CAN NOT LOAD CANON PALM PRINTER P1-DHV
Where I was guiding the paper, after feeding the paper through the back of the machine (the slot is located on the outside of the back of the machine), the paper naturally wanted to enter underneath the black plastic plate where it would end up underneath the entire printing mechanism. As the instructions indicate, the paper does not actually feed "under the black plastic plate", it should feed through it. There are two rectangular silver tabs, one on each side of the proper paper entry slot. I cut the paper at a very slight angle and finally found the magic entry point. Also if you make an arrow with the paper by folding the sides, it will help guide it in that tiny silver slot. Because the machine is so tiny, that entry slot is almost invisible, except for those two silver tabs. After you manage to insert the end of the angled cut through the "invisible slot" be sure the entire edge of the paper actually enters the slot so that when you push the "Feed" button, the paper is grabbed and fished through evenly. Hope this helps somebody!
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; document.getElementById("ga_300x250").style.width = "370px"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'loading  printer paper - abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //-->
Posted on Oct 12, 2008
  • Marilyn Greaves Jul 06, 2013
    Thank you for solving my problem. As soon as you said through the rectangular silver slots it just clicked. Not realised it had to come up through the silver slots.
Just achieved this feat. (After 2 days of trying.)
Paper should drape over from back (like toilet paper, the correct way).
Cut sides to a point. Paper will have the natural tendency to point upwards and drop into rollers (or guide). Now feed through.......
Should work.
After you feed through and see the tip of the paper, you realize how simple it is.
-shirley
Posted on May 13, 2009
How do i load my printer paper ti-5045sv
To load paper into a ti-5054 sv calculator.
  • Turn Calculator on.
  • Press down on the front edge and slide in the direction of the arrow.
  • Insert paper on the roller so that the paper rolls out toward the bottom, and the loose end is closest to the calculator.
  • Cut of the end of the paper.
  • Insert the end of the paper into the printer slot in the back of the calculator.
  • Press the paper feed button ( karmahm_0.png) until the paper is in position.
Mar 17, 2011 | Texas Instruments TI-5045 SVC Calculator
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
Need to load paper into calculator
There is a small flat area on the back of the calculator. Put the paper in this hole and press the FEED button.
May 06, 2010 | Canon P170-DH Calculator
P26-dh III - I am also unable to load the printer paper. I can't figure out how it is to be fed in.
It is necessary to feed the paper through a slot on the back of the printer in the dark gray area. Feed a single paper through and push the FEED button. When you see it appear, feed the paper through the clear serrated slot on the top cover over the printer.
Mar 18, 2010 | Canon P1-DHV Calculator
I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
Feb 05, 2010 | Casio HR-8TMPlus Calculator
Printer paper loading
Just achieved, after trying for 2 days
Paper should drape over like toilet paper.
Cut sides to form a point in the middle.
Feed through back of machine. Paper will have a tendency to point upwards.
Guide though metal roller, then hit feed........should go through.
May 12, 2009 | Canon P1-DHV Calculator
Loading the paper
Cut the paper off clean.
Slid it through the slot on the back.
The place the paper between the black plastic rail,
and the bottom of the calculator.
Keep feeding it in the slot untill you can see it under the
foam wheel.
The repedably hit the feed button until the paper comes
out the other side.
If it does not feed, the paper is not under the wheel far enough.
This should work on other similar models as well.
Dec 24, 2008 | Casio HR8TM Calculator
I cant' get new paper installed on desktop calculator
There is a small **** right where the paper roll gets installed - it looks like the seam between the top and the bottom of the calculator. The paper feeds from the roll directly into this - maer sure you have a very clean edge to start with - then turn on the print function and push a button until it starts to feed through. Be patient with it but it will work.
Dec 20, 2008 | Canon BP120 DH Calculator
Loading paper
The entry point is on the back bottom of the machine. Cut your paper into a shallow triangle w/a slight point in the middle. Guide it through the slot on the back, and then lift that point up so that it goes into an almost invisible opening with small silver metal tabs on either side. The paper will want to feed underneath the entire black plastic mechanism, but don't let it. As the instructions indicate, the paper does not actually feed "under the black plastic plate", but through it. After you manage to insert the point of your paper through the correct slot, make sure the entire edge of the paper actually enters so it is grabbed when you push "Feed."
Jun 17, 2008 | Canon P1-DHV Calculator
Trouble Feeding Tape into Calculator
use a thin plastic card and put it on the load,maybe you have a paper on printer ,press feed and you vill clear all paper path
Feb 01, 2008 | Canon P170-DH Calculator
Canon P1-DHV Calculator Logo
1,702 people viewed this question
Clive
Clive
old marine
old marine
