Question about Panasonic CT-24SX12 24" TV
We won our tv in a charity tournament. it displays " now in picture refresh mode." it appears about every 5 min, it resets volume and colour
2 Suggested Answers
SOURCE: Panasonic 32 inch TV has horizontal lines across screen
REPLACE VERICAL OUTPUT IC ' LA7838
Posted on Feb 05, 2009
How to perform factory reset procedure pro1150hd
Factory Reset Procedure
1 With TV off/in standby....press home menu.
2 Within 3 sec turn TV on , Integrated Menu will appear.
3 Hold Display button until Final Setup appears in the top menu.
4 Arrow leftor right until yes appears in lower menu.
5 Hold enter until menu disappears.
6 Wait 1 min.
7 Power TV off and unplug from the wall for 5 or more min.
You can also try this:
Home Menu, select Picture, select "Reset", then ENTER, then select "Yes" and press ENTER.
May 09, 2014 | Televison & Video
Dx-ldvd22-10a does not power up what part do you think broke
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you saveicon1.png any picture settings such as brightness or contrast.
To get the TVicon1.png out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with "Dynamic Mode" shown on the screen. At this point the picture parameters can be changed and saved.
If this method doesn't work for your TV there is an alternate method that might.
From the buttons on the front of the TV (not the remote):
1) Press the Volume + (increase volume) button
2) Whilst the volume button is pressed, press and keep pressed the menu button
3) Let go of the volume button and keep the menu button pressed for 5 seconds
4) After this time the screen should go blank and "Dynamic" will appear at the bottom of the screen.
from
http://www.fixya.com/support/t399140-samsung_le46f8_picture_setting
Jul 27, 2013 | Televison & Video
I have a sony kds-r50xbr1 when turn-ed on the stand by light flashes for about a min the goes solid and picture comes on but very dark. replaced lamp . there is no sound from any input and the controls...
Sir try to reset the lamp timer. you should press the "display" button on the remote then "5" then the "volume up key" and power "on" you should do this while the tv is in standby mode. Then press "Jump" 3 times to enter the DE service menu. Your tv will display the total lamp hours. Reset the lamp time by pressing channel 3, then mute, then enter. this will make your lamp hour timer to zero. Good day and best regards.
Aug 21, 2011 | Mitsubishi VS-50609 50" Rear Projection...
The words "Digital Noise Filter
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
Digital Noise filter off , digital noise filter on and auto visualization is always displayed in my Lcd samsung series 4 even though i turned it off in Picture options , digital noise filter is changed to...
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Aug 13, 2010 | Samsung LE40R74BDX 40 in. LCD Television
My Sony Bravia has no colour, and the black and white is so dark you can't see the picture. It is less than 1 year old model # KDL-46S5100
If the picture has no color or appear as black and white only, please reset the picture setting. To reset picture setting please follow the items below:
  1. Press MENU button on your remote.
  2. Press arrowtb.png to select setting.jpgSettings, then press ok.png.
  3. Press arrowtb.png to select picturemenu.jpgPicture Menu, then press ok.png.
  4. Press arrowtb.png to select Reset, then press ok.png to reset all the Picture Settings except Picture Mode and Display Mode to the factory settings.
If this does not not work, then change the picture board in your TV.
Please rate my solution.
Good luck.
Jun 27, 2010 | Televison & Video
I need to reset the clock on a sony rds car radio i changed the car battery & the clock reads the wrong time & hasn't reset itself, how do i do it manually?
I Realised that I needed to press the shift button to go into set-up mode then press 2 repeatedly till clock appears, press 4 hours flash, set hour by turning volume knob, press 4 again mins flash, change via volume knob, then press shift twice to return to normal setting, the same applies to setting colour, & display (scrolling mode).
Nov 08, 2009 | Sony Car Audio & Video
Every 10 minutes my Panasonic plasma 720p turns mute
the problem is it is locked in store mode. I had to call panasonic to fix it, this is what they had me do.
1 hold the volume down on the tv while holding the menu button on the controller.
2 after the screen changes to the check menu, hold the off switch on the tv untill it turns off.
3 unplug the tv for 30 sec.
4 plug it back in and turn on the set.
5 select home option
6 your done.
Jan 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
I GOT A PANASONIC PLASMA TV 2 DAYS AGO..SINCE THEN EVERY 5 MINS A MESSAGE SHOWS UP ON THE MIDDLE OF THE SCREEN SAYING: "NOW IN PICTURE REFRESH MODE. GOING TO RESET SETTING" HOW CAN I FIX THIS...
  • Unplug the TV and plug it again.
  • Press and hold down the front POWER button.
  • If TV doesn't power up, use remote power on while holding down the button on the set
  • You will be prompted to chose between STORE and HOME mode... select HOME
You should be good to go.
Jul 09, 2008 | Televison & Video
Keeps going to refresh mode
This is the Panasonic Customer Service Answer:
you need to reset the unit to get it out of store mode sir
make sure the unit is on and we are not in any menu screens
press and hold the volume down button on the front panel
and ok on the remote at the same time until the words self check appears on the front of the screen
once self check is displayed unplug the unit from the wall for one minute
after one minute plug the unit back in and it will go back through first time setup
make sure you pick the home mode
Apr 19, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic CT-24SX12 24" TV Logo
16 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
