Question about Maytag Performa PAV2200
Washer wont continue to run
My washing machine will start to run on spin cycle, then it just stops like its not geting enough powere to run it. Any ideas
    Genius:
  • 1,061 Answers
Warn drive belt...or motor going bad.richardm69
Posted on Dec 14, 2008
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Bosch WFO2865GB that stops before the Spin cycle
probably not draining fast enough, check for blockages at filter, sump, outlet and plumbing
Mar 29, 2010 | Bosch Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Unit runs good through wash cycle then while in rinse and spin does not complete cycle. The machine starts doing a short spin, and then dial starts turning around without stopping.
Sounds as if the drain pump is not ejecting the water fast enough. Did you notice of the washer is draining more slowly than usual or at all?
Feb 14, 2010 | Splendide 2100 Vented Washer-Dryer
My Haier waching machine has a slow spin cycle
I have the same problem with the same washer
Jan 26, 2010 | Haier Washing Machines
Washing Machines Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
