Question about HP Compaq Presario SR1300NX (PP195AA) PC Desktop
Compaq SR1350NX Had a powersurge, now computer says "no signal". I can still see the "mode" select screen and other screens. I don't think it is a video card issue.
  • 492 Answers
Well you are prob incorrect. Computer components are very vulnrable to power surges. Especially video cards. If you do not have both computer and monitor plugged into a suppressor or protector, more than likely it is your motherboard, video card, or cpu.
Posted on Dec 09, 2008
    Sergeant:
    Champion:
  • 277 Answers
Check your video connection and memory ram
I have a presario cq61 and have forgot my password can u help
Try starting the computer in safe mode. Turn on the computer and once the COMPAQ screen clears press F8 a few times - don't hold down the key however. Winodws stops loading at teh Startup Options screen (black, text only). From that menu use the cursor keys and ENTER to select "Safe Mode". Once Windows loads (it may look humungous!), login as the Administrator (which should now be visible). Use this account to reset your forgotten user password. Restart once complete - the computer will automatically start normally.
Apr 14, 2011 | HP Compaq Presario CQ61420us Notebook
The Screen turns black when I attempt to start windows normally. It sounds like windows is starting, but nothing appears on the screen
It sounds like windows has been set to a screen resolution beyond the limits of the capabilities of the built in LCD. Luckily windows has a menu that allows you to change to a highly compatible low resolution mode. To select this mode, start tapping the [F8] key just after the HP/Compaq screen when the computer switches on. Hopefully if you pushed the button in time, you should be presented with a menu. Use the up and down arrows on the keyboard to select the option that says either "Enable VGA Mode" or "Enable Low Resolution Video (640x480)".
Windows should now load, but everything will look extra large. To fix this, go into your display properties (right click on desktop and select either "properties" or "screen resolution"), and choose the recommended screen resolution.
Dec 24, 2010 | Compaq Presario CQ60-220US PC Laptop
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
Won't boot past the XP screen
go to bios and select boot option first boot cdrom,
i think f12 press then select boot order, if still cant dvd rom or rw, maybe week,
thanks
Oct 09, 2009 | Compaq Presario 700 470024-192 Notebook
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Not Loading
i m sure its some kind of maser problem with u r system...
because at the 1st time when u select safe mode it should work .....i think some big data dammage have made....and now u are unable to recover it....
so my suggession is that u can re install win xp on u r computer..
regards..
for any quarry u can mail me at-sigma_shiva1@yahoo.co.in
May 18, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
Monitor Message = "No Signal"
see i use Compaq too
they don't generally except other modes
did u try that monitor with other pc where it worked
u should install proper monitor software ... u will found it from the cd given wit Ur monitor
Apr 24, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Desktop monitor
Hi
Disconnect the monitor from the tower and then turn on the monitor.
If u get a msg like no input signal or check video cable then the monitor is fine. If this is the case, it could be a problem with the tower or the cable.
Dec 31, 2007 | Compaq Presario 5BW284 (202493-003) PC...
Using 42HP66 as a Computer Monitor for a Compaq Presario 2150NX Desktop
Reboot your PC! When the pc starts booting up push F8 it will take you to the same screen asking you if you want to run the pc in safe mode! What you want to do is to select the Start PC in VGA mode! It should set your video card to a default setting allowing it to work with the TV!
I hope this helps you!
Please feel free to call or message me if you need more help!
Dave
1-503-432-9904
pleasefixitdave@yahoo.com
Oct 20, 2007 | Toshiba 42HP66 42 in. LCD Television
HP Compaq Presario SR1300NX (PP195AA) PC Desktop Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
