Question about Nikon N75 35mm SLR Camera
E won't turn off
My camera suddenly stopped working. It's new too. The Error light won't turn off. Please help. I tried changing batteries, taking the lense off and putting it back on again. Thanks!
  • Anonymous Nov 26, 2007
    I have the same issue. The E won't turn off on the camera. How do I fix this? Need any suggestions.
The "E" just means "empty". As in "no film". The "err" is different. It cold be anything. sorry i don't have a solution for that.
Posted on Feb 09, 2008
How will i fix my samsung S860?
The only safe way is to take it in for service so there is no further damage done.
Dec 21, 2012 | Samsung S860 Digital Cameras. 8-megapixel...
My Power Shot SX130 IS wont turn on... I dont know why, yesterday was working and all the sudden today I tried to Power On and doesn't do anything. I changed the batteries .... HELP!
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 11, 2011 | Canon PowerShot SX130 IS Digital Camera
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Broken?
check out the memory card... try taking pics without the memory card in and see if it is still doing the same thing
Dec 15, 2008 | Olympus FE-210 Digital Camera
Says lens error!!!!!
The best solution is to take it to Best Buy and have them look at it. The Kodak camera could still be under warranty.
Jun 30, 2008 | Kodak Easyshare M753 Digital Camera
A lens error requires to be sent into repairs. Give them a call at 800-706-2534 option 2.
Apr 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Red light flashes and LCD turns off and on
A quick test would be to purchase a set of Duracell Ultra Digital batteries and try them. They won?t last for very long; however, if they make the red light go away then you problem is either the batteries you are using or the charger. More often than not its going to be the batteries so we?ll start there: Check your batteries, you should be using Nickel metal hydride (Ni-ME) that are rated at 1450 (I use 2500) mAh or better. If the batteries are more than one year and you?ve used them a lot then its likely the batteries just aren?t holding a charge anymore. Purchase a new set or borrow a working set from a friend. Charge them in your charger and try in your camera, if the red LED goes away use the batteries till they need charging again. Charge them in your charger and if the red LED stays off then the batteries were the problem. If the red LED returns then try charging your batteries in someone else?s working NiME charger. Put them in your camera and if the red LED goes away then your charger is the fault.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Pink screen
Back to store or maker with it. Check out the makers Tech support site but this needs a new camera replacement.
May 16, 2007 | Kodak EasyShare C643 Digital Camera
It acts like it's turning on, but doesn't
Hi: With your description of the problem it seams to me that your camera doesn't have enought energy to continuo working properly. The view pictures mode always takes less energy to work while the shooting mode... a lot because it has to load several things on the camera, including the access to the card. My advice is for you to try with different batteries but with a lot of mAh. The recharchable batteries have those numbers that, in a small definition, the higher the value more pictures you can take. Try to get 2 x AA batteries with at least 2100 mAh and try the turn on your camera. I think it will solve the situation. ;) Regards
May 21, 2006 | Polaroid i832 Digital Camera
Nikon N75 35mm SLR Camera Logo
70 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
TC CAMERA REPAIR.Com...
Are you a Nikon Photography Expert? Answer questions, earn points and help others
