Question about Boating
MK Maxxun 74 run at high speed
The speed adjustment on my MK Maxxum 74 runs on high. The on/off switch is ok. When I press the button it takes off wide open.1st time it happened nearly threw me out of the boat..
Thanks a bunck
jim
A boat owner friend of mine is going to fix it in exchange I take him to my favorite fishing hole.
Thanks
Posted on Dec 10, 2008
Kyocera FS1370 reset
Press Menu button, then press the up arrow until you find the Adjust/Maintenance. Press the right arrow and search with the up arrow the Service choice. Then press the right button and search with the up or down arrow for Maintenance. Press the OK twice and the Install MK will disappear.
Mar 26, 2014 | Kyocera FS1370DN Laser Printer
What is the factory setting for lowand high screws on 25cc craftsman blower
If the two screws are side by side, one is the high speed mixture screw and the other is the low speed mixture screw. To set the high and low adjustment screws, tighten the screws in until they stop, don't force the screw after it stops. Back each screw out 1 1/2 turns. The engine will start and run here if everything else is ok. Fine tune each adjustment screw by closing the screw off (CW) until the engine runs rough. Back the screw out (CCW) until the engine smooths out. Run the engine at full speed and adjust the high screw. Let off the trigger and adjust the low screw. Once the mixture screws are adjusted, you can turn the idle screw to adjust the idle speed. It can take some time getting it all adjusted.
Nov 20, 2013 | Garden
Casablanca fan intelli touch
there is a starter solenoid inside it works the speed setting. controls speed 1-2-3. 4 it bypasses it. in side the fan you will see a black box with c66 somthing that will need to be changed as that is the part that controls the speed.
Oct 17, 2013 | Dryers
How to use continuous shooting on canon powershot sx40
Set your camera to high speed continuous shooting, track the action, and just before the peak press and hold the shutter release button. The camera will take a series of pictures and hopefully one of them will catch the action at its peak.
If you're asking how to set the camera for high speed continuous shooting, Turn the mode dial to SCN, press the FUNC/SET button, select the overlapping rectangles, and press the DISP button. Full details are in the "High-Speed Continuous Shooting" section of the manual (page 74 in my copy). If you need a manual you may download one here.
May 09, 2012 | Canon Cameras
Camera exilim ex-s600 will not take pictures outside,pictures turning out white,yet will take pictures inside ok.is this a worthwhile repair
This seems to be a software problem with your camera. Your camera should, if on AUTO mode, automatically expose your photo accurately. Try half pressing the shutter button (used to take pictures) while outside to adjust focus and exposure, then press the button fully to take picture. If your camera cannot adjust to take a properly exposed picture (not bright white), then it is possible that the shutter speed is stuck on a too high speed, outside daytime shutter speed should be fast (1/1000 sec). Or if your shutter speed adjust accurately, it could be the aperture if the aperture is not small enough for daylight shooting. This is likely a software problem. Try adjusting your settings manually and see if the picture turns out!
Sep 10, 2011 | Casio EXILIM Card EX-S770 Digital Camera
The small saw serial #1J295L669 starts O.K. and runs for about a minute, but then dies on me. there is a high and low adjustment screws;however the cover over the carb. seems to have an effect before and...
Most of carburetor has three buttons to adjust. L (low), H (high) for fuel injection at low and high speeds. There is also a minimum (the chain must be stationary if it is well tuned). The chainsaw is set at low rpm throttle with screws ( L ), and its vivacity is set at high speeds ( H screw ). In the beginning is good put both to set at 1.5 turns from full closure. And then, if the chainsaw starts, you can adjust a carburetor work. Careful with adjusting with H due to high speed.
Sep 06, 2011 | Poulan Garden
Carburetor is running rich.
Hi jim paton...
You may have some trash/debris in your jets that is causing your engine to run rich, or maybe some did not adjust the high speed/idle adjustment screws properly
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
Normally you will adjust your idle jet to 1/2 to 3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2 to 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Free Answer...Please take time to rate me
Jun 13, 2011 | Garden
Ran aground on lake,now stuck on high speed,can't lower speed
My Minn Kota 55 powerdrive had the same problem except mine occurred while it was trailered in the yard. High speed only, everything else worked great. From what I could research the control module is a frequent problem. Took a chance and purchased a new control module and this cured the problem. Maybe this happening and running aground was just concidental.
Apr 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Poulan pro bvm200 leaf blower/vac won't run on high
Is the exhaust spark arresor screen clean? a blocked exhaust will do this.
Nov 29, 2008 | Garden
New maintenance kit
Hi Did you run up the developer unit? Menu button down to Other then to Service and press enter on developer and switch off and turn on will run for a while. In the service menu after you run up the dev unit you may have a option in there to press enter on the MK Symbol.
Cheers
Jun 12, 2008 | Kyocera FS-3900DN Laser Printer
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
