Question about IBM ThinkPad R51 Notebook
Hello my IBM R51 is powering on but then not making it past the IBM screen page to my login befor eit blacks out.
  • 3 more comments
  • phildombek Dec 10, 2008
    thanks ron for your help i will get with you in a couple minutes
    Ron
    Nothing happened when I followed the steps above. I did speak with a IBM rep and IBM says I will need to purchase system recovery disks to help with my problem. Does this sound right? if not please help me solve this problem.
    Phil
    Ron
    Thanks for you help and yes I will get back to you either way.
    Thanks for everything.
    Phil
  • Anonymous Apr 10, 2009
    My ibm thinkpad r51 pc notebook turns on but when it gets to the point for the login screen it dosnt go there it says error launching installer
  • Eric Mitchell
    Eric Mitchell May 11, 2010
    By blacks out does it stay on or does it turn off?
    Sergeant:
  • 324 Answers
Phil,
Well, sorry those didn't do it for you. Unfortunately, a lot of of people seem to be having this type of problem, and there seems to be a lot of different fixes that work for some cases and not for others. I gave you some of the cheap and easy fixes first, hoping that would help.
What has fixed a number of these is rebuilding back to the orginal factory load. For various reasons, this black screen can be a symptom of your hard drive information having gotten scrambled. And that is why he told you to get the disks. Those disks may seem a little pricey but they are worth their weight in gold when you need them. If you can afford them, I suggest that you go ahead and get them. Will they fix your problem? Most probably, but no guarantee.
If the disks don't do it for you, get back to me and we'll see if we can come up with something else. If the disks fix it, I'd appreciate a note letting me know that,if it's not too much trouble.
Thanks and have a good one!
Ron
Posted on Dec 10, 2008
    Sergeant:
  • 324 Answers
Try the following to see if these tips might help:
1) Power off, remove the power cord, remove the battery, press and hold the power on button for 30 seconds, or so. Plug the power cord back in and try to bring it back up again.
2) Power down, remove the memory module(s) and reinsert them. Try to bring it back up.
3) Power down, remove the hard drive and power back up.
4) Power down, replace the memory module from a working machine.
Get back to me as to what happens.
Ron
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
Jul 21, 2009 | Computers & Internet
Blank Screen
First, confirm that it is the screen itself. Connect the video output to a known working monitor and then power on your Thinkpad. if the known working monitor behaves the same way you can rule out the laptop's monitor as the source of the problem. This may be the BGA, Ball Grid Assembly, leadless soldering problem related to video chips on the motherboard, but first test the monitors.
Apr 15, 2009 | IBM ThinkPad R51 Notebook
I cant login
friend
just use the xp disk to repair the installation
hope it will solve your problem
thanks
Apr 10, 2009 | IBM ThinkPad R51 Notebook
R51 Thinkpad Monitor Problems
To answer your question Morgan, yes you can get a new LCD display for your laptop! Typically people sell the entire assembly which is the screen, backlight, display cable. It then fits into the thin plastic casing around your current screen. They are actually pretty easy to replace the problem is you oftentimes have to remove the computers keyboard, and other pieces of plastic on the top that might be in the way. Also there are usually anchoring screws on the bottom that have to be removed as well. There should be one little teeny tiny cable you have to pull out that connects to the mainboard, and then reconnect with the new display. Try this website if you want to order a new one their price is only $120 (which is great for a new LCD screen).
http://www.blisscomputers.net/servlet/the-44892/IBM-R51-THINKPAD-LAPTOP/Detail
Feb 21, 2009 | IBM ThinkPad R51 Notebook
Ibm thinkpad r51
What is the default password for my R51 Thinkpad by IBM Model # 2888?
Feb 04, 2009 | IBM ThinkPad R51 Notebook
IBM R51 and is having a problem at startup
try removing all the memory modules on the system, usually you'll get beeps. if you do get a beep try one memory module at a time see if you get something on the screen, observe also the lights on the system see if they would stay on or blink or flash. its rare that a virus would attack the BIOS, more-likely a bad motherboard or harddrive can be prevent the computer from starting up. hit me back on the results. thanks!
Jan 08, 2009 | IBM ThinkPad R51 Notebook
My Laptop R51 1830 IBM can not turn on
Is there no repair shop near by. There could several thing wrong but I cant tell from 4000 miles away which.
May 24, 2007 | IBM ThinkPad R51 Notebook
IBM ThinkPad R51 Notebook Logo
248 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
