Question about Maytag MMV5000 Microwave Oven
Microwave works for a few seconds and then the lights and turn table inside shuts off.
Microwave works for a few seconds and then the lignt inside goes off and the turn tables stops as well. The food is still cooking, but we shut it down. We tried starting it again, but it gave the same results. We unplugged it for a few minutes and then it worked, but then again the inside lights and turn table stopped functioning. Any ideas besides replacing the sucker? Thanks, Victor.
  • 38 Answers
Re: Microwave works for a few seconds and then the lights...
Hi the light and turntable work of a common relay located on main pc board.relay probably dry jointed or sticky or check switches behind door catches
Posted on Feb 27, 2007
0 characters
3 Points
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
Shm1816s Samsung microwave oven wont shut off All lights off turn table not turning but you can hear the humming. the turn table plate gets very hot.
if the turntable is getting hot it means that the microwave is working but as the turntable is not turning , it means the adjustment of the door lock of your microwave may have become improper due to use.may be it got damaged.
call the technician of samsung microwave ,he will open the cabinet of microwave and make the adjustment of door lock proper.
Oct 19, 2013 | Microwave Ovens
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
PLMBZ209GCA Professional Series microwave: the timers and lights all work but NO Microwave?
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link:
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
Feb 01, 2013 | Microwave Ovens
Bosch hmb5050 shut down after 30 seconds
It may be turning off because it is not heating, does it have the lights inside and the turntable both working?
Dec 10, 2012 | Bosch Microwave Ovens
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
Glass inside does not rotate now
The problem is typically the turntable motor, it is accessible by first disconnecting the power then removing the lower panel that houses the filters and lights. You will see a small device with 2 wires that looks similar to this
b162a2f.jpg The next most common thing to fail would be the coupling that attaches to this motor and sits inside the oven, you can take the glass tray out and lift the coupling, check for cracks or breaks, try running the microwave for a few seconds without the table and see if the coupling turns with the weight of the table on it. This may indicate a stripped coupling.
The 3rd component and most expensive to fail is the control itself, there is either a relay or diode on the control that sends a signal to the motor to turn. You should verify that you have power to the motor before replacing it.
I hope this helps
Apr 25, 2010 | GE XL1800 1100 Watts Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Whirlpool microwave mh6150xls makes noise while running
The oven may not be seated properly. check the bushes at the bottom.
Apr 07, 2008 | Whirlpool MH6150XMS Microwave Oven
Maytag MMV5000 Microwave Oven Logo
317 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
