Question about GE JVM1630 Microwave Oven
Fan runs when door is closed
Suddenly, when the door is shut, a fan runs. It is a seperate fan from the exhaust. The microwave still works & heats. We must leave the door open.
  • Anonymous Jan 24, 2009
    door closed fan wont shut off
  • Anonymous Feb 26, 2009
    fan came on and would not go off until I unpluged it
    Problem Solver:
  • 15 Answers
This is an interlock issue or a faulty temperature sensor. Both will require the outer casing to be removed for inspection. Basic tests can be done with a continuity tester or cheap digital multimeter with resistance checking facilty (Radioshack)
The sensors for these types of fans are normally attached to the roof of the cooking cavity, little silver components with two or more wires.
Check these out with a meter if any are open circuit then they need to be replaced.
Posted on Dec 10, 2008
  • Gus Dec 10, 2008
    Sorry the interlock issue is more complicated and relies on at least two or more microswitches to operate when the door is closed, look around the opening for any loose plastic, observe opening and closing of door to see if the switches operate., Please observe HIGH VOLTAGE precautions with cover emoved there can be upwards of 5000 volts present with it unplugged!
    Lastly does the light operate when the door is shut? If so, its likely to be a switch issue/controller malfunction.
Roper Microwave fan won't shut off
THE FAN AND MICROWAVE TUBE RUN OFF THE ELECTRONIC TIMER. OPENING THE DOOR SHOULD SHUT IT ALL DOWN AND WHEN YOU CLOSE THE DOOR AGAIN YOU SHOULD NEED TO PRESS THE START BUTTON AGAIN. IF NOT, ITS SOUNDS LIKE AN ELECTRONIC RELAY IS LOCKED CLOSED ON THE TIMER BOARD.
Aug 28, 2007 | Sharp R-1610 Microwave Oven
Maytag mmv4205bab continues to run after time is up. The fan does not circulate, but it continues to heat.
Our microwave in office won't shut off. It continues to heat and fan is running as soon as we close the door. Tried everything, unplugged, canceled everything. Please let me know what to do.
Oct 04, 2010 | Maytag MMV4205 Microwave Oven
Starts when closing door
This is a list of possible causes. 1. Defective triac or relay 2. controller is confused (pull power cord for a minute and see if it resets) 3.Defective controller or touchpad.
Mar 02, 2010 | Microwave Ovens
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave high intensity light turning bright orange
You have a shorted grille relay on your control board. I can repair this for $69.95, which includes insured return shipping.
For details and more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | KitchenAid KHHS179LSS Convection /...
Humming ge sapcesaver microwave
During operation, most of the built-in models have a panel that tilts out while the exhaust fan is on. When cooking is done, the exhaust fan shuts off and the panel retracts to its normal position. With the fan & microwave motor off, the hum is easier to hear. Look closely at the top panel the next time you hear the hum, and you'll probably see that it's retracting.
Jan 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool OTR microwave no oven 'fan'
FIRST ,,MICROWAVE OVENS ARE REALLY SAFTY MINDED AND THATS A GOOD THING....THERE ARE USUALLY THREE DOOR SWITHCES NEXT THE KEYBOARD--THE ONE ON TOP AND THE ONE ON BOTTOM ARE PRIMARY AND SECONDARY SWITCHES,,YOUR PROBLEM SOUNDS LIKE ONE OF THESE IS NOT MAKING CONNECTION..YOU MIGHT BE ABLE TO PRESS 'DOWN" WITH A LITTLE PRESSURE ON THE DOOR AFTER CLOSING TO SEE IF THE FAN WILL START,,,IF YOU NOTICE --THERE ARE 2 LATCHES(HOOKS) COMING OUT OF THE DOOR,,WHEN THE DOOR IS CLOSED,THOSE LATCHES ARE SPRING LOADED AND MAKE CONTACT ON THOSE SAFTY SWITCHES....THIS IS NOT A CUSTOMER REPAIR--MICRO'S ARE JUST TO DANGEROUS WHEN YOU TAKE THE COVER OFF--IF THIS DOES BRING THE FAN BACK ON--YOU GOT A BAD DOOR SWITCH AND SHOULD BE A REASONABLE REPAIR
THE OTHER SOLUTION STILL WOULD BE A CONNECTION PROBLEM ON THE KEYBOARD ITSELF-THE WIRES JUST PLUG ON THE CIRCUIT BOARD BEHIND THE KEYBOARD---STILL A EASY REPAIR--GOOD LUCK TUNICA
Oct 30, 2008 | Microwave Ovens
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Exhaust an won't shut off
One of the things that well cause that to happen is the voltage Reg. sticking close. thats only one thing there are 7 others that well do that you need to find a electronic Tech who can look at it for you.
Aug 28, 2006 | Whirlpool MH6150XMS Microwave Oven
GE JVM1630 Microwave Oven Logo
208 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
