Question about iLO (2 GB) MP3 Player
How can I save the 5-band equilizer settings?
I am haveing to go in and readjust the settings on the custom 5-band equilizer settings everytime I turn it on. Is this standard or am I missing something? This player would be great if it wasn't for this annoying problem
  • 8,596 Answers
The firmware upgrade that might have resolved this problem is no longer available
Posted on Jul 06, 2008
Can the bands be tighten in the transmission on a 1991 lincoln towncar
Tightening the band will not acomplish anything
The band is brought down tight on the drum,when
the unit is built or rebuilt,then you loosen the band
approx 1 &3/4 turns,and that is it,forever,done.
As the band wears do you need to readjust
You can but it is a waste of time,you won't gain
much in the way of reduced travel or apply time.
The point here is,band adjustments fix nothing
and are not preventative maintainance in my
experience
Feb 03, 2011 | 1991 Lincoln Town Car
I have a Canon MP460 & cannot print DL envelopes from a .pdf as there is a grey band showing in preview:composite. Nothing prints in this band. How do I remove it?
This appears to be a bug with the Canon software. It is not using the correct dimensions for a DL envelope.
The solution is to use a Custom Paper Size. Make it 110mm wide and 220mm high (which are the correct dimensions for a DL envelope).
To make it easy to select this size in the future, set the Custom Paper Size (plus any other options you want) and then click on the Save button. When the save dialog appears, click on Options and make sure that "Save the paper size setting" is checked. Then enter a suitable name (e.g., "Envelope DL Custom") and click OK.
Nov 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Every time i turn my truck off the equilizer resets
If you radio doesnt save the stations either when you turn off the truck then it could be your wiring.. For example; Normally you have two power wires.. A red one(Accessory).. and a yellow one(Battery). The yellow one is like the memory.. and the red one powers the stereo when you turn the key. Try switching yours over.. See if that helps. Easily confused and you wouldnt really notice the difference.
Jan 14, 2010 | JVC KD-R200 Car CD/ MP3 Player
What is the Standard Setting to start with for a graphic equilizer
All the bands set to 0 or unity gain. Usually the faders have a 0 or marking showing no cut or boost on each band. This should be straight across and a flat line.
Oct 19, 2009 | Alesis iO 26 Sound Card
Everytime I turn on my computer I have to readjust brightness
if you are using windows Operating system Go to control panel & click power options & set the requuired brightness.
Oct 11, 2009 | Acer Aspire 7720-6712 PC Notebook
Philips HTS3555 custom settings reset to factory on its own
this happens when the electricity is fully discharged
May 17, 2009 | Philips HTS-3555 System
Setting of new paper size from epson lx-300 +II
your solution works fine with me, but the problem is i can't able to save the settings on the printer. so everytime i need to print on that given custom sized paper type, i need to manualy select it from advance tab on printer properties before i have a good print-out..
Anyways,Thank you very much.
Apr 13, 2009 | Epson LX-300+ II Matrix Printer
Having Trouble Accessing Bass and Treble Controls
Only parametric EQ OR Bass/Treble can be active at a time. There is a option to set which one you want, refer to manual. Follow this- Adjusting Sound Setting Mode (long press "sound-mode" button) -> EQ SELECT-> select either P. EQ or B/T
Feb 18, 2009 | Clarion DXZ785USB Car CD/ MP3 Player
Optimus 7 band equalizer model # 12-1969
I need to know what the wire are coming out the back of the optimus seven band stereo frequency equalizer/booster
Jul 07, 2008 | Car Audio & Video
Video settings reset everytime I turn off TV
Hit the menu button on the remote. Click on Setup. Then click on Set The Quick Start Options. Make sure it is on. That should solve your problem.
Jan 15, 2008 | Hitachi P42H401 42 in. Plasma HDTV
iLO (2 GB) MP3 Player Logo
60 people viewed this question
Top iLO Audio Players & Recorders Experts
Siul Oyaratgam
Rick
Rick
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
