Hp 2015dn paper jam light on solid,won;t print
Hp 2015 paper jam light is on solid, not blinking. Printer won't print.
  • 8 more comments
  • Anonymous Dec 28, 2008
    There is no solution only to buy a new printer
  • Anonymous Dec 29, 2008
  • awier Jan 02, 2009
    Paper light came on. Check all doors and added paper. Light will not go out and printer will not print. Checked for paper dust or small pieces of jammed paper. Nothing.
  • Franek Jan 16, 2009
    paper jam light on without actual paper jam
  • bluecheeze Jan 19, 2009
    frustrating. same problem
  • Anonymous Feb 10, 2009
    I have the same problem. Paper Jam light on, not blinking.
    I have the same problem. Paper Jam light ON not blinking.
  • Anonymous Feb 27, 2009
    I also have the same problem and I have seen people replace the printer engine to no avail. I believe you would need to exchange the printer
  • Anonymous Mar 06, 2009
    same
  • Anonymous Mar 13, 2014
    Says :"paper jam" and won't print, however, there is NO paper jam
This is a widely known problem with this printer and means the formatter board needs to be replaced. Save yourself the cost and headache of repairing and move on. The problem initially began as a random situation where I would have to turn the printer off and back on to get it to print.This eventually progressed to the problem you all are reporting which is the amber toner and jam lights on. I replaced the formatter board on mine and after one month the problem returned with the new formatter board needing replaced as well.
Of course, HP acts as if they've never heard of the problem. This company's integrity and quality has gone from number 1 to dead last.
Posted on Apr 21, 2009
  • 3 Answers
There is a manual paper release on the bottom of the paper tray. If it gets stuck the paper does not rise to be picked up. Not sure why it registers an amber paper jam for it, but I taped my release open and put the tray back in carefully. Its been working for 2 days straight now.
My real issue was I had both the low toner and paper jam lights on solid and amber. I waited a few days to post this to make sure it worked. Worth a shot for you all. post back if it works for you .
-T
Posted on Feb 27, 2009
Thanks so much. HP wanted to charge me $40 to ask this question.
James Harris
Posted on Mar 30, 2009
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
Sep 04, 2014 | Lexmark E Office Equipment & Supplies
Hp laserjet 2015 printer shows an indicator light error that theres a paper jam but actually no paper jam or paper particles . I have cleaned aii the sensors and checked the paper path. Powers on well...
restart it
if problems insist check if sensors are working
if are working you need to replace motherboard
of your printer that cost to high
you better replace your printer
hope i had help you
Nov 26, 2010 | HP LaserJet P2015 Printer
My HP 610C printer yellow light is blinking after the paper is taken in. The power light is steady. Therafter the yellow light blinks continuosly. Please help.
Follow each of these steps until the problem is resolved:
  • Remove the paper from both paper trays.
  • Press the power button once. Wait a moment for the paper jam to clear.
  • If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  • Remove the rear access door.
  • Remove the paper jam through the opening at the back of the printer.
  • Replace the rear access door.
  • Reload the paper into the paper In tray.
  • Print the document.
Sep 29, 2010 | HP Office Equipment & Supplies
HP 2015dn paper jam light remains on; no paper jam
What is "cold" reset? Have you tried pulling the power cord out of the back of the PRINTER, wait one minute, and plug it back in. Wait another minute - that should do it.
Jul 09, 2010 | HP DeskJet F380 All-In-One Printer
HP LaserJet P2014 keeps showing paper jam when there is no paper jam. How to clear?
If paper jam light is solid than checked paper path sensors and toner sensors and if they are aligned correctly than perform cold reset(Keep pressing and holding the green button) if still the issue persists and orange light remains solid than i m sure formatter board is faulty and we need to get formatter board replaced.
Thanks and Regards
Neeraj Sharma
Jul 01, 2009 | HP Office Equipment & Supplies
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Solution
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
Solution
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
Solution
  1. Load paper in the paper tray.
The printer might have a paper jam.
Solution
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
OR
if the print carriage is stuck or making a grinding noise, then follow these steps.
Solution
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Solution
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
HP Laserjet 2015 dn
It means that the printer is in READY State.
Control panel
The printer control panel is comprised of six lights and two buttons. The lights produce patterns that
identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Sep 08, 2008 | HP LaserJet P2015dn Printer
3,741 people viewed this question
jasbo
jasbo
