Question about Jenn-Air JED8430 Electric Cooktop
Right front burner on high all the time.
On my jed8430 the right front burner stays on high all the time it is on.How do I replace switch if needed,do I have to remove unit from counter?
  • BCHardeeCT Dec 21, 2008
    I have the exact same problem. Had to turn it off at the breaker. Any ideas?
  • jjiang Dec 29, 2008
    I had the same problem
  • 135 Answers
Yes, the entire unit must be lifted out - it is probably secured with screws underneath. Then you can remove the screws on the underside of the glass to access the switch. Hope this helps!
Posted on Jan 01, 2009
One of the burners stays on high. can that be fixed?
Hello, Thank you for your post. Sounds like your having a problem with one of the burners on your cooktop. Yes, you can have this fixed. The burner that stays on high has a bad infinite switch. Once you change out that switch your cooktop will work as normal.
Happy Holidays!
Please rate me "4 thumbs" if this information was useful.
Dec 20, 2010 | Jenn-Air JED8430 Electric Cooktop
Front burner won't come on. Others fine. Have checked breaker. Is there a reset fuse?
Sorry but no. If you have a burner not working it will be 1 of 2 things. 1st the switch that controls that burner is bad which would be the easiest and less expensive to replace. The other is the element. Good luck but I really do feel it will be the switch.
Feb 10, 2010 | Jenn-Air JED8430 Electric Cooktop
When the larger burner on the right is on high is melts the plastic control nobs. How do I fix it? Thanks Jim
These burners are not supposed to be operated uncovered. If indeed the burner is covered and it is still causing the controls to burn than the resistance for that burner is failing and the burner should be replaced. Thank you, Dana
Oct 06, 2009 | Jenn-Air JED8430 Electric Cooktop
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Tripping breaker
Replace the burner and receptacle and you should be short free. You may also need to replace the surface element switch too if it doesn't come on at all or stays on high regardless off knob setting.
Dec 16, 2008 | Jenn-Air JED8430 Electric Cooktop
Three of my Jenn Air burners (electric) only work on High - OLD
Hello
Welcome to Fixya
My name is Huum,
you can find the schematics, diagrams and parts here at this site . just enter the complete model number that is written on the stove sticker and access the info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
Please remember to leave a rating before you leave
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Problem with double burner Jenn-Air JED8430 Electric Cooktop
It's an ignition switch. don't change the burner cartridge.
May 10, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air Electric cooktop
did you replace the limiter the long rod that goes across the element or just the element everything i can find says that's the culprit
Dec 29, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
279 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
