Question about Panasonic CT-36HL42 36" TV
Hello, My Panasonic ct-36HL44 won't turn on. It's complestely dead. Yesterday and for the last 4 years---its been perfect, completely reliable. What happened? Is there a fuse inside the chassis and can I replace it myself? Or muct I lug this 180 pound monster to the repair shop? Thanks!
  • 2 more comments
  • optivity Dec 25, 2008
    I have the same problem with a CT-36HL42, which is most likely caused by a failed power supply.
    Does anyone know how difficult it is to replace the power supply for a technically inclined DIY individual?
  • Anonymous Dec 26, 2008
    I have the same problem with a CT-36HL42, which I believe to be the result of DOA power supply. Happened earlier today. If I find anything, I'll post it.
  • leeannb Dec 26, 2008
    I have encountered the same problem. Any more info on the fuse location?
  • randymullica May 03, 2009
    I have the same problem (for the second time). It cost me about $220 to replace a switch the first time. The TV worked for about 8 months and then it went out again. Is this something that easy to replace?
  • 4 Answers
I can concurr with "Mario in NY" solution. My CT-36HL42 would not power on but after replacing the fuse (6A125V?) it is operational.
Posted on Jan 20, 2009
I had the exact same problem with this model a few months ago. Repairman came out to my house and told me that Panasonic is well aware of the problem but never issued a recall on it. He then charged me $150 to take off the back of the tv and replace a blown fuse with another fuse with a slightly higher voltage rating. Took him all of 5 minutes. He took off back of tv and the fuse is located, if you are standing at the back of the tv, on the bottom in the left hand corner. You can't miss it. I wish I could tell you which fuse he put in but I didnt see it. Sorry. Try it for yourself and you might be able to save $149.50, b/c I doubt that fuse cost much more then 50 cents. Good luck.
Mario in NY.
Posted on Dec 26, 2008
Camera won't turn on
check the age of the batteries bc my rechargeable ones only lasted 4 years and they wouldnt even hold a charge for a couple of pics
Aug 15, 2012 | Panasonic Lumix DMC-FP3 Digital Camera
TV was working one second and we turned it off.
press the key setup or menu and select restore by default,
if no solved your problem, you need get support technical panasonic
Mar 07, 2010 | Panasonic CT-36HL44 36" TV
The TV will not power on at all
Is the set completely dead? if so you should see no indicator lights and hear no "click' when the power button is pressed. If so than the only thing wrong with the set ic the main Fuse (6.3A 250VAC) has blown.
Sep 19, 2009 | Panasonic CT-32HC14 32" TV
Dead TV Panasonic CT 36HL42CF
have a visitation and bury the next day.
Jul 14, 2009 | Panasonic CT-36HL43 36" TV
NO POWER OR LIGHTS WHEN POWER BUTTON PUSHED
Hello and welcome to FixYa!,
It sounds like the Power Board on you TV has Died, you will need to replace it in order for your TV to work again
Hope this helps --Full Str Pka
Dec 30, 2008 | Panasonic Televison & Video
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Panasonic CT-36HL44
is the orange wire a plug in or is it broke off the crt board if so solder back together
Nov 14, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Tv is completely dead
Only 10 years old??? Ok its most likly at the end of its usefull life, unless you want to put some cash into the set, as there are no user replaceable parts inside this TV, so you really should let a trained tech estimate it for you. But once you fix it, you most likly will start have problem after problem. Do yourself a favor, and buy a new one. The problem with this set is most likly the flyback and other componets or the power supply capacitors are bad.
Sep 30, 2006 | Panasonic CT-32G11 32" TV
TV does not turn on
I'm looking for the same info... my CT-32sx12f is completely dead too. I was wondering if the IC regulator or the flyback is bad. Fuse is fine. Anyone have any wisdom or experience on these sets they can interject? Thanks!
Sep 05, 2006 | Panasonic CT-32SX12 32" TV
3year old Panasonic ct-32sx12f dead?
Sure, Why not? It is worth the effort. If the set is 'dead', it is the easiest to repair.Only 'tampered' sets pose problems. It could be a simple blown Fuse, or the Power Regulator IC. This should not cost you more than $100-150 as Technician charges + 15-20$ for spares. It could also be a defective Horizontal Outut Transistor and short cicuiterd FBT, (tho' it seems remote), but if yes, add another $100. definitely worth calling a professional techie
Aug 22, 2006 | Panasonic CT-32SX12 32" TV
Panasonic CT-36HL42 36" TV Logo
443 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
